2000 maxima radio problem, help.
Old Sep 20, 2003 | 12:35 PM
max2000x's Avatar
hi, I'm new to max forum. Problem need to be fixed it the factory radio.
Car works great, no problem. All electronic works with the exception of the factory Radio unit, It doesn't work. No power is going to it. What could be the problem?
If you say it's the fuse, then which fuse? where is it located. need to know. thanks
Old Sep 20, 2003 | 12:49 PM
Dohcser's Avatar
Fuse is locted on the driver side under the dash board. there is a panel to take off and it is labled which fuse is for the radio.
Old Sep 20, 2003 | 12:54 PM
max2000x's Avatar
If not the fuse, then what could the problem be?
thanks
Old Sep 20, 2003 | 01:19 PM
Dohcser's Avatar
well then you will need to get behind the HU with some sort of tester to test the voltage and ground.
Old Sep 22, 2003 | 01:47 AM
myktek's Avatar
try this after checking the fuses....i had my car into an accident and i had same prob as u...and after i got it back it was working, they said they didn't touch it, only thing they did besides body work was pull the battery terminal off and put it back....so try that....
Lakersallday24
Nov 7, 2024 07:31 PM
kjlouis
Nov 24, 2018 06:09 AM
jholley
Aug 11, 2015 09:38 AM
kirkhilles
Aug 8, 2015 10:53 AM
niZ
Aug 7, 2015 10:18 PM
