Need Help Please
Old Sep 30, 2003 | 09:00 AM
jkyi30's Avatar
Need Help Please
Everytime i turn my car off and start it back on, the dvd player did not stay in the same position, it start all over again. My question is did i wiring it wrong or its this just the problem with the cheap dvd player? If it is the dvd player, do anyone here know where or what brand and model that stay in a same position even i take the key out of the ignition
thanks
Old Oct 2, 2003 | 08:31 AM
subs1000w's Avatar
the audiovox din size one should keep the memory with no power i think cc sells it for 200$ but you could probobly get it somwhere else for less
Old Oct 2, 2003 | 10:54 AM
Kojiro_FtT's Avatar
thanks
Would help if you told us what DVD player you have. Also, look to see if the other settings are saved. Like aspect ratio preference and languages. If not, then yes you probably wired it wrong.
I know most of the name brand players will remember the position.
Old Oct 2, 2003 | 08:57 PM
jkyi30's Avatar
the dvd player is some brand call vizual logic. Thanks
Old Oct 3, 2003 | 06:15 AM
Dohcser's Avatar
Sounds like the wire that is supposed to be hooked to a constant 12V you probably have it going to ignition. Definately check your power wires, let us know how you hooked it up.
Old Oct 3, 2003 | 10:11 AM
jkyi30's Avatar
Thanks. I didn't do the hooked up my self, so i dont really know. But I will ask the installer and check to see just to make sure.
