Subwoofer question?
Old Oct 1, 2003 | 10:39 PM
esc92's Avatar
Subwoofer question?
I'm going to be purchasing a 5-channel kicker amp to run my interior speakers and it says I have 200w for my subwoofer output. Now I already have 2 12" subs (BS-Hollywood Excursions) in a box powered by a 300w audiobahn amp. My question is if I keep the Audiobahn amp and put some better, but not too powerful, subs in can it be powered by the Kicker amp w/o blowing or messing anything up? Since the Audiobahn is powering those subs will it give them more power that the 200w the Kicker pushes out? Mind u that the Kicker already has a bass control ****...will it still be able to control the base too? Thanks in Advance!
Old Oct 2, 2003 | 11:31 AM
maximamaybe's Avatar
Yes, your kicker amp will push one sub very we ll. Audiobahn would be nice also. A damn good sub for the money is the Kicker Comp VR 12. It is ~$80 from www.ikesound.com
Old Oct 2, 2003 | 11:37 AM
esc92's Avatar
My question is can I get more power out of the subs i have if I have an additional amp hooked up to it?
Old Oct 2, 2003 | 02:12 PM
lunchbox's Avatar
you want to have 2 amps hooked up to your subs??
Old Oct 2, 2003 | 02:19 PM
No. I had a BP600.1 that blew.
Now I am running a PG Octane R amp on my sub.
In the future, I will be installing a BP600.1 on my sub and move my PG amp to components.
Sorry for the confusion.
Old Oct 2, 2003 | 02:22 PM
lunchbox's Avatar
Maximamaybe, you didn't confuse me...the original post did. It sounded like he wants to run 2 amps to the subs at the same time. Thats what I was talking about.
Old Oct 3, 2003 | 10:41 AM
esc92's Avatar
I'm sorry for the confusion. What I was trying to do is hook a 300w amp that I have for my subs to the 5-channel 700w amp that I will have the interior speakers too. Is that possible?
The other idea is: I already have a 300w 2-channel amp for my subs. I was going to get a 4-channel amp for the interior speakers. Probably in the near future sale that 300w amp and get a 800w instead.
Does that make sense now?
Old Oct 3, 2003 | 11:20 AM
lunchbox's Avatar
hook the 300 watt amp to the 5 channel for added power to the sub? no. Just use the 300 watt amp for the interior speakers and the 300 watt amp for the subs.
Old Oct 3, 2003 | 11:53 AM
esc92's Avatar
So what type of connections do I use to run these two amps? Like should I use one power wire and then a splitter to the two amps? Why is that the ground wire shouldn't be very long?
Old Oct 3, 2003 | 12:11 PM
You have 3 good options.
1. Run the main wire to a distibution block then split one power off for each amp. (Fairly cheap)
2. Run the main power wire to a fused distribution block and then split off 1 wire for each amp. (Around $25-$30)
3. Buy a 1 farad cap and then buy some terminal connectors. Run the Main power wire to the cap input, then run seperate wires from the output to each amp.
Number 3 si what I will be doing.
Old Oct 5, 2003 | 08:18 AM
jmax
There is a 4th option as well. Run from the battery to a Dist block. From the distribution block or fused block run power to your mids and tweets amp. Run a second large wire from the fused D-block to your cap. Then from the cap to the sub amp. This way you get the best benefit from the cap. If you put a fuse between the cap and sub amp you eliminate the benefit of the cap with the resistance in the fuse. I never thought about this before meeting Mark Eldridge at the JBL Engineered Mayhem tour a few weeks ago. But it makes perfect logical sense.
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
