need an experts help
Old Oct 4, 2003 | 11:09 PM
taeMAX97's Avatar
i recently bought and installed alpine cva1003 with dva 5205. and also added non-alpine vcr to go with it. and i can't get my vcr to work. i get the picture but there is no sound coming from it. but if i disconnect ainet cable between headunit and dvd it works. what can i do to make both work(not at the same time)? because if dvd works then vcr don't and if vcr works then dvd don't work. i called alpine tech support about 10 times and they all told me to get video switcher(they also told me to disconnect-->basically ignore the ainet cable) but without ainet cable hooked up dvd wont even power on. any suggestion? please tell me there is a way to run these two without spending lot of money.
thanks,
Tae
Old Oct 5, 2003 | 08:08 AM
jmax
The video switcher sounds like the answer. You would need this in your home system if your home receiver could not accept more than one video signal and have a built in switcher. Many still connect their old TV's, VCR's and DVD's this way. Alpine also makes a device for adding a second source. I just don't know if it has video capability. Most of the details are in your CVA1003 owners manual.
Old Oct 7, 2003 | 11:39 AM
TAPOUT's Avatar
You will lose
You need to add the TCS-V430A. It is a TV tuner, but it also does multi sourceinput, and output. That will solve all your problems.
litch
123
Jan 4, 2024 07:01 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Sep 21, 2015 12:41 PM
robtroxel
Sep 8, 2015 08:15 PM
