DVC wiring
Old Oct 7, 2003 | 09:16 PM
Momaxima's Avatar
DVC wiring
Hey yall i was just wondering, how do you wire dvc...do you connect the negative on one coil to the negative on the other coil with a piece of speaker wire, and then run another wire to the amp from one of the negative coils and do the same thing for the positive?
Old Oct 8, 2003 | 05:29 AM
Dohcser's Avatar
It all depends:
Lets say that you have a dual 2Ohm sub. You can either get it to run at 1 or 4 ohms. You need to know if you amp is stable at low ohms.
Parallel: (2ohm DVC = 1ohm)
(-) to (-) and (+) to (+)
then take the negative from one side to the negative of the amp and same for the positive.
Series: (2ohm DVC = 4ohms)
(-) from one side of the sub to the (+) of the other side of sub. Then take the (-) not being used and run it to the (-) side of amp and the (+) not being used and run it to the (+) of the amp.
Old Oct 8, 2003 | 06:41 AM
Kojiro_FtT's Avatar
Read This
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
