Car Video Question
Old Oct 12, 2003 | 08:33 AM
95spdMaxSE's Avatar
Car Video Question
Ok, I plan on putting some TV screens in my Maxima but I had a few question. First out how do you hardwire a DVD player, VCR, or a PS2 to the carso you don't have to use the cigarette lighter? If I decide to use TVs on the headrests as well as the dash, how do I connect them together? If I put the video sources in the trunk will the remote work though the car (if i'm in the drivers seat will the remote work if the DVD player is in the trunk?) Finally, what do I do about A/V wires, are you able to buy 10'+ so I can run wires from the trunk to the dash? Any help will be helpful. Thanks guys.
-Kevin
Old Oct 12, 2003 | 08:59 AM
N34JZ's Avatar
Needs non-Maxima Friends
-Kevin
to hardwire the dvd player, ( Im assuming your not using a mobile one? ) or a ps2 get a power inverter off of ebay or something, then just clip the cig. plug off and connect the positive wire to the battery (you can run an inline fuse to be on the safe side if you want but most inverters have a fuse built in, just use the same size as the inverter and put the fuse no more than a foot from the battery)
then run a ground and you can plug you PS2 or whatever your using into it. One thing Ive noticed though is that you have to turn the power switch on the power inverter on everytime it is shut off, so that means going to the trunk and flipping the switch or you can move the switch to somewhere else in the car, just make sure you make your connections good (solder and heat shrink)
now for connecting mutiple TV's. buy a video amp off of ebay (I think there is a good clarion one on there right now) then run the power for that off the battery (Im not sure if it has a remote turn on, if not but a switch and put a switch on the positive line before the video amp)
then you plug your RCA with the video signal into the input side then just run RCA's from the outputs to your screens
Remote: I know my mobile dvd player has a wired IR eye for the remote that you can mount it up front and that just plugs into the dvd player so you can use the remote in the front.
Wires: yes you can buy longer lengths of wires just try to keep the distance down but you should be alright if you get the video amp, and make sure you keep the video and audio signal wires as far away from the power wires as possible.
I think thats it
Old Oct 12, 2003 | 09:02 AM
N34JZ's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...category=32826 here is a video amp, its the best one on there, I couldnt find the clarion one and I know the XO vision one dont work that well
Lakersallday24
Jun 16, 2019 01:35 AM
mikekay
Aug 10, 2015 12:52 PM
spidgeon
Aug 9, 2015 09:26 AM
13Maximasv
Aug 7, 2015 10:56 AM
Jcof88
Aug 3, 2015 10:43 PM
