how do ohms work?
Old Oct 21, 2003 | 11:10 AM
Mrfrog's Avatar
how do ohms work?
Just wondering if there was a site that explained the differences in ohms in subwoofers/amplifiiers. 2ohms 4ohms 8ohms. which is the best. Thanks!
Old Oct 21, 2003 | 12:09 PM
kgb006's Avatar
8ohm are usually for home entertainment systems
4ohm are most of the car audio
2ohm is mostly used with subwoofers to squezze all the power out of the amps
2-8 ohms is just the resistence rating
Old Oct 21, 2003 | 12:13 PM
Irish's Avatar
This is a democracy
1 ohm is the best thats me
Old Oct 21, 2003 | 09:46 PM
Kojiro_FtT's Avatar
Less resistance means more noise from the amp. Subs can run at 2 or 1 ohm because noise is less noticable at lower frequencies. More resistance will give you a clearer sound, but you need a bigger amp to push the watts at higher resistance. That's why car speakers are 4 ohm instead of 8 like home systems, to reduce the size of the amps. That's also why Bose systems in cars run at 1 ohm, so the amp can fit in with the speaker in the door.
If interested, check the specs on your amp, or an amp you are looking at buying. A typical THD % (total harmonic distortion) is like 0.08% at 4 ohm, but more like 0.3% at 2 ohm, and ever higher, like over 1%, at 1 ohm (if the amp is 1 ohm stable).
Old Oct 21, 2003 | 09:57 PM
AscendantMax's Avatar
http://www.soundinstitute.com/article_detail.cfm/ID/99
Old Oct 21, 2003 | 10:08 PM
erty67's Avatar
Decal Specialist
speakers are rated in impedence, not resistance
Old Oct 22, 2003 | 02:16 PM
kgb006's Avatar
a speaker is a resister in a way
Old Oct 22, 2003 | 02:45 PM
erty67's Avatar
Decal Specialist
...a speaker is a coil
MAXSE5SPD
Sep 17, 2022 04:00 AM
jskirwin
Jun 8, 2016 08:49 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
