Alarm Siren- Pain Generator piezo
Old Nov 8, 2003 | 08:40 PM
Nismo's Avatar
anyone have one on their alarm? how loud are they? are they worth it?
Old Nov 10, 2003 | 05:14 PM
Maxstilln's Avatar
I have a Pezo horn mounted in my vents, really loud, bright, can be painful at the right time. Are they worth it? That's up to you, I got mine really cheap and wanted the added level of comfort, just sucks when I program my alarm cause I forget its there till it chirps
Old Nov 10, 2003 | 09:42 PM
Nismo's Avatar
how are they connected? do I just wire the wires to the one on the main siren?
Old Nov 14, 2003 | 07:42 PM
Ramses718's Avatar
How would you hook something like that up?? I wanted to hook up an air horn to my alarm but I heard if you hook it up to the siren channel you can end up burning it out and then your screwed.
Old Nov 15, 2003 | 07:11 AM
Supa Lao's Avatar
If it's the little piezo siren (dei 513t)from dei, I have one in my engine bay. I can that thing more than i can hear my normal siren. It is loud. For ~$20 I would get one. You just hook it up like your normal siren
Old Nov 15, 2003 | 11:39 AM
Nismo's Avatar
So do I just splice it to the wires of the regular siren? or do I plug it in the brain? I didnt install my alarm myself so im not too familiar
Old Nov 15, 2003 | 01:35 PM
TAPOUT's Avatar
You will lose
I have 2 of them in my air vents right above the radio, and they are well worth the price of admission. It is ok to hook 1 up to the existing siren output, but when you get more than one on there, you should run them from a relay. The other cool thig about them, is that if you are going to install them yourself, there is a little hole in the back of the air vent that you can use to mount the siren to. Take off the little bracket on the siren, and use the screw to anchor it to the side of the vent. You will see it as soon as you pull the air vent asembly out of the dash, right on the outside edge. Good luck.
Old Nov 15, 2003 | 03:07 PM
Nismo's Avatar
thanks for the response. Im going to order one shortly. How do they sound acutally? loud high pitch screech?
Old Nov 17, 2003 | 05:28 PM
Nismo's Avatar
Does it beep when I arm/disarm the alarm too?
Old Nov 17, 2003 | 07:25 PM
Supa Lao's Avatar
If you hook it up to the siren, then yes.
Mar 12, 2020 12:06 AM
mkaresh
Mar 12, 2018 06:48 PM
rbaksi
Mar 25, 2016 06:10 AM
BobTX10
Oct 7, 2015 08:43 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
