Premium System Interface wiring question
Old Nov 9, 2003 | 08:05 PM
ArcticDC5's Avatar
I am replacing my Bose head unit in my 91 SE, and need some information about wiring. On the interface, there is common ground wires for each speaker, do I wire these into the positive wirese in the wire crimps? or do I leave these out? Is there one audio return for all 4 channels also?
Old Nov 12, 2003 | 08:45 AM
jmax
Common ground? Sounds like that connector was hand made in the 1970's. You should be able to find all the info you need in the FAQ's.
Old Nov 14, 2003 | 06:31 AM
BML94GXE's Avatar
Maxima Withdrawl is real
do you mean where you send the + to the speakers and ground the - to the car? That was what they did in older cars for low wattage headunits.
Old Nov 15, 2003 | 07:41 AM
Supa Lao's Avatar
Your max is definitely not going to have common ground. If your bose amps are doing good and not cracking or popping when you are turning it amp, I would just get a new h/u. But if they are, I would reccomend getting new spkrs in the process. If your amps are fine. Just head out to your local Circuit City or Best Buy and buy a bose amp interface plug. Should run you ~$50 for the harness and pick up an antenna adapter too. If you have a double din radio, might as well pick up a universal pocket too
rbuswell
Nov 17, 2016 04:54 AM
flu2000
22
Sep 2, 2015 07:29 AM
Abdelrhman
Aug 17, 2015 12:16 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
