Soundproofing..............
Old Feb 22, 2001 | 06:00 PM
SilverBullet98's Avatar
I need to sound proff my car, but I need some advice. I have a limited budget so I cant afford the Dynamat...I was looking at the stuff on JC Whittney.com, has anybody used it and if so is it worth it ??? Which stuff did you guys use...I saw a couple of different products....Thanks for any advice
Old Feb 22, 2001 | 10:09 PM
SWEETSOUND2001's Avatar
http://www.mcmaster.com $12.70 per 12 sq. ft. roll. Exact same as dynamat original for 5 times less. Email me for more info and also visit my website.
Old Feb 22, 2001 | 10:12 PM
94SUPERMAX's Avatar
It's verry hard to sound proof a car without the right stuff.
But if you are on a budget then use lots and lots of tape to hold thing's in place and stop them from ratteling.
That's what I did in my verry first car, and it worked quite well. Although I don't think it would work for a car with a good system in it.
Old Feb 23, 2001 | 05:55 PM
Maxstilln's Avatar
Check out the spray Dynamat. I used it and it much easier than conventional stuff that you have to heat with a heat gun and roll into place. If you don't roll it properly it will peal and than it was all a waste of time A can should cover about half of your trunk depending upon how much you plan on convering. I think the can sell for about $10, 2 should do it. HOWEVER be very careful!!! Over spray is very easy to get on the car, it will come off with a clay bar but easier to avoid it. Another inexpensive alternative is rubberized undercar spray or chassie spray. I bought a can of that for about $6 and it does the same thing! Good luck
1995 GXE 1st Place NOPI Nationals
Old Feb 23, 2001 | 08:52 PM
Where did you get the spray from ??? the rubberized undercoating stuff....
