quick 2k2 bose question
is the oem h/u powered or not?? i've heard conflicting descriptions that it powers the speakers, and others say that it only puts out a pseudo-preamp to the bose amp which powers the speakers and sub.
anyone know for sure???
Originally Posted by ABS
AFAIK, for Bose on 2K2 and later, the HU is a pre-amp (just like aftermarket HU's). It drives a small four channel amp mounted under the rear deck in your trunk. That amp also has a pre-amp output that feeds into the powered sub that is mounted on the rear deck . . . Hope that helps.
I wish someone that has added an amp to their Bose would chime in... Where are the postwhores when you need them?
G
ok, well both of your posts are somewhat in-line with what i've heard here. what i read is that the outs on the bose h/u are preouts, but they're some proprietary voltage so that necessitates the pac adapter to make it work with aftermarket pre-ins. that's for the speakers and the sub. no problem there.
what worries me is that i called daveb for some of the harnesses i'd need for the wiring and he informed that he's reasonably sure that the h/u is powered... hence my post.
dvcamp
Sep 18, 2015 10:17 AM
