power inverter question
Old Dec 15, 2003 | 09:50 PM
glass88jaw's Avatar
I will be putting in a ps2, and was wondering the best/easiest method to power it. If I was to hardwire the inverter to the cig adaptor, would there still be power flowing when the car is turned off? I don't want to kill the battery. Would it be better to just plug it into the cig adaptor only when using it? The only downside to this I see is it will be kinda ugly... Also what wattage power inverter is best for just running a ps2? thanks, kevin
Old Dec 15, 2003 | 11:33 PM
Jake9190's Avatar
You could wire a relay with a switch to turn the power on and off. I believe if you tap off of the cig adapter, it should turn off when the car is off (since the line is switched with the ignition). I can't remember, but we have ran a PS2 and a small TV off of I think a 300w. These things can be had relatively cheap now, so I would go a little higher than the 'minimum'
Old Dec 22, 2003 | 06:58 PM
RI-Max's Avatar
bump!!! i need some info 2.
The Frye
Sep 2, 2021 11:03 AM
Maximan190
Dec 16, 2015 06:01 AM
AT978
Sep 6, 2015 10:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
