Amp Problem
Old Dec 17, 2003 | 07:27 PM
ill30's Avatar
Amp Problem
hey, i just put a sub in my car. i had an amp( JL 500/1) already and new it worked. the problem is the power light comes on but the sub doesn't. i tested my old sub and it didnt work either, any HELP, thanks
Old Dec 17, 2003 | 08:12 PM
dracip's Avatar
Did you ajust the sensitivity input (maybe it's set at the minimum level) ?
Old Dec 17, 2003 | 08:23 PM
ill30's Avatar
i checked that but the sub isnt moving at all. i checked the wiring and everything is correct
Old Dec 17, 2003 | 09:58 PM
nismos14's Avatar
§è~® f®ÈÄk
did u pull the rca plugs to see if u hear a pop from the sub when u do so? if u hear it that means ur getting signal for sure, if u dont then theres either no signal coming through, or the amp is screwed up. also try pulling the fuses out of the amp, and putting them back in with everything off. also inspect the fuses to see that none is blown out.
Old Dec 17, 2003 | 10:19 PM
ill30's Avatar
The JL doesnt have an onbored fuse, could it be the one under the hood, i'll check in the morning, thanks
Old Dec 17, 2003 | 10:20 PM
nismos14's Avatar
§è~® f®ÈÄk
it COULD, but if the amp is lighting up, then it probably isnt blown. check anyways.
Old Dec 18, 2003 | 10:21 AM
kgb006's Avatar
do you have sub woofer controls on your deck? maybe your sub woofer is turned off
Old Dec 18, 2003 | 07:11 PM
ill30's Avatar
well it turns out the amp went bad, i took it to the shop, theyre gonna send it out to get it fixed, thanks for your help
ivorton23
Sep 28, 2015 09:08 PM
popdedop
Sep 11, 2015 11:17 AM
