Adding passive crossovers to Stock Bose.
Old Dec 21, 2003 | 08:31 PM
nismos14's Avatar
§è~® f®ÈÄk
Has anyone added passive crossovers by adding capacitors in line to the speakers on a bose system? i am going to try to bypass the bass going to the rear speakers so i can turn up the bass **** on the stock bose head unit, and only affect the bass going to the sub, hoping for cleaner and louder sound, with less distortion.
Old Dec 22, 2003 | 10:02 PM
nismos14's Avatar
§è~® f®ÈÄk
also leaning towards a crossover point at around 200 hz, bc my sub is crossed around 180 and the roll off on the bose will be about 6db at the 200 hz crossover, the subs are rolling off at about 18db on the 180 hz cross
Old Dec 23, 2003 | 03:46 PM
jmax
I would lean toward a getting a new headunit with seperate sub pre-out and level control. The bass **** center frequency is normally in the midbass range.
If you are set on putting something in line with the bose speakers I would look into getting something line level before the bose amps. Otherwise you need to measure the nominal resistance of the bose speakers to determine your cap value. Also keep in mind that most cheap caps add some of their own sound to the system.
Old Dec 23, 2003 | 07:53 PM
nismos14's Avatar
§è~® f®ÈÄk
i dont want to upgrade the headunit right now, so im more inclined to go with the caps. if i do it line lever before the amps i will affect the amps i have running the subs, i dont want to do that.
Old Dec 23, 2003 | 08:55 PM
jmax
Line level before the bose amps. Not before the sub amp.
Old Dec 23, 2003 | 10:03 PM
nismos14's Avatar
§è~® f®ÈÄk
got ya, good idea, thanx!
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Dec 12, 2015 09:39 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
