having trouble with my keyless entry...
hello....I am having trouble with my aftermarket keyless entry install.....I must hit the button three times is a certain order to unlock my car....please tell me what is wrong...I have a black widow keyless entry only system and I can't figure out why I must hit the button so many time...I just want to hit the unlock button once ...I also know all about the double pulse unlock thing....it is wired for that...I think that there may be a small miss wirage on it....please help me....it's a real pain thanks...dave
If you're sure that it's programmed for double pulse, then I'd check reception first. Maybe if you can get the antenna higher? If you connect the antenna to ground (or anything else) that can mess up reception. I'd also check batteries and wire connections if this doesn't help. Maybe the button on the transmitter is picky, but if you get a good solid push then it'll only take on push? Hope this helps.
