Component Crossovers
Old Jan 8, 2004 | 06:17 AM
Fins1020's Avatar
I was thinking about doing an install on my own of MB Quart DSE-216 and DKE 116. Are the crossovers for the DSE's passive or active. Anyone have a step by step of wiring for components for a 2002 Maxima? Can you use the original wires or do you have to run new ones? I don't have the bose system.
Adam
Old Jan 8, 2004 | 09:56 AM
largestal's Avatar
factory wiring is substandard for aftermarket speakers and/or amplifiers. Run new stuff - always safer. Not sure about the xovers.
Old Jan 8, 2004 | 10:59 AM
kgb006's Avatar
Adam
you can use original wires if you gonna power your components off your deck, if you are planning to amp them, rewiring is a must.
components are very easy to wire, hide x overs in the doors or the kick panel, conect (+ - ) wires as labeled, tweeters go into the pillars or for a more custom look you can put them in doors
Old Jan 8, 2004 | 12:03 PM
slickrick's Avatar
where do the tweeter wire and woofer wire meet? on the back of the h/u? i need to install my xovers so id like to know this b4 i do it.
Old Jan 8, 2004 | 01:03 PM
kgb006's Avatar
the wires from the deck go into the x-overs, x-overs split the tweeter and the woofer wire
Old Jan 9, 2004 | 09:09 AM
max'n out's Avatar
there passive
Old Jan 9, 2004 | 09:14 AM
Pearl96Max's Avatar
I tend to get a bit irritable
They are passive. And I strongly recommend an amp for them. MBQ will do the same and go one step further to tell you if you dont there is a very strong possiblity they will blow. HU is not a clean enough signal to run components.
--Don
Old Jan 9, 2004 | 09:36 AM
Fins1020's Avatar
what amps are best to use with mb quart
Old Jan 9, 2004 | 11:42 AM
Pearl96Max's Avatar
It really comes down to opinion and budget. There really isnt a "best" amp,speaker,etc..
BTW..your only about 20mins away from me, shoot me a PM or email. Im sure I could help a bit.
-_Don
RealityCheck
Oct 2, 2015 06:34 PM
msellas
Sep 23, 2015 09:16 PM
