adding a sub with stock nonbose HU...
Old Jan 8, 2004 | 06:21 PM
exardus's Avatar
I'm sure this had been asked before, but i couldn't search for some reason. I have a 97 Max with non-bose system, and i wanted to upgrade my sound system abit. I wouldn't want to spend money on a head unit right now, so i was wondering if there's a way to add an amp and subs to the stock HU. Would i have to buy some king of converter to hook up an amp? would sound quality be much lower than using a $150 HU? also would i be able to use the bass function of my stereo to adjust the subs?
PS. I was going to use 2 10in Alpine Type R's, and i'm not sure on the sub yet.
THanks alot!
Old Jan 8, 2004 | 10:08 PM
nismos14's Avatar
§è~® f®ÈÄk
THanks alot!
Yes you can add them, you don't need an adapter, u can splice the speaker wires into rca's and use those as low level input on the amp (rca's). no the sound quality would not be much lower than using a $150 hu. yes you would be able to use the bass function of the stereo to adjust the subs.
Old Jan 8, 2004 | 10:16 PM
02MaXiMa_GLE's Avatar
Well, you don't even have the details of your car in your .org Profile... fill that out and people will be more willing & able to answer your questions the first time around.
Try this link for more info:
http://forums.maxima.org/showthread.php?t=276498
Also, check STUDMAN'S second post in the AUDIO FAQ.
G
Old Jan 8, 2004 | 10:30 PM
OneToughMax's Avatar
I wouldn't recommend this. If you're going to splice into the speaker wires, you will want to plug them into the HIGH level (speaker level) input on your amp. If you want to use RCAs, you need a line-out converter, to down-convert the high level speaker signal into low-level RCA signal for your amp.
Old Jan 8, 2004 | 10:53 PM
nismos14's Avatar
§è~® f®ÈÄk
the output level of the bose headunit is low, they are preamp's to the bose amps. i have had mine running for a while, no problems. to each their own.
Old Jan 9, 2004 | 12:45 AM
exardus's Avatar
i'm pretty sure i have a nonbose stereo. what kind of converter would i need, could you suggest a place to get one?
Old Jan 9, 2004 | 01:33 PM
nismos14's Avatar
§è~® f®ÈÄk
all you need is a line output converter, any electronics store including best buy and such woud have it
Old Jan 9, 2004 | 01:34 PM
nismos14's Avatar
§è~® f®ÈÄk
and you were right, it was my mistake, the nonbose would have higher outputs than the bose since they are more than just preamp signals. i wouldn't do it my way either unless you have a bose stereo.
Old Jan 11, 2004 | 02:54 PM
exardus's Avatar
ok, thanks alot for the info. I think i'll pick up a converter with 2 "gold plated" outputs from a local audio store for about 50 bucks. So down the road i can add an amp for my speakers.
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Dec 12, 2015 09:39 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
