sub question
Old Jan 21, 2004 | 06:57 PM
bennny
sub question
my friend has a 10'' sub in his max and it works only when you push in the sub...like any kind of force pushed in it will start to hit, i didnt have much time to check out all the wiring or anything but what could be your first accusations at whats wrong? i told him i would ask around, thanks!
Old Jan 21, 2004 | 07:14 PM
nismos14's Avatar
§è~® f®ÈÄk
my first "accusation" is that the voice coils wiring has come loose, or the wires on the terminals have become loose (disconnected)
Old Jan 21, 2004 | 07:22 PM
AscendantMax's Avatar
i don't think that's it, since it plays normally after an initial push to get it to move. if the wiring is lose, won't it play sporadically due to the cone movement.
how hard did your friend play his sub?
Old Jan 21, 2004 | 07:45 PM
bennny
just mid levels to show that it worked perfectly fine when u applied pressure, it was an infinity, he said his friend wired it up and it was a pretty ****ty looking box and a stock deck, had a jensen amp and converter i think
Old Jan 21, 2004 | 08:37 PM
TAPOUT's Avatar
You will lose
Your voice coil is probably seperated. It will probably start working if the volume is turned way up too. It is getting the electricity to make that first jump across the gap that is a problem.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
