Dash kit for 2 single din components
Old Jan 24, 2004 | 07:48 AM
jjyznaga's Avatar
Anyone know of a good dash kit to install 2 single din components. I am adding a dvd player to my stereo so I will have a stereo and dvd in my dash. Any suggestions would be appreciated.
Old Jan 24, 2004 | 02:52 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Why not just get a DVD, stereo. There are no dash kits that accomidate double din, you would have to modify the regular kits.
--Don
Old Jan 24, 2004 | 04:19 PM
Ka$hThaRipper's Avatar
i think studman has a double, im not sure if he got it customized tho...check it out here..
http://maxima.theowensfamily.com/audiosystem.asp
Old Jan 24, 2004 | 05:23 PM
Pearl96Max's Avatar
Looks like a modified Metra or Scoshe kit.
--Don
Old Jan 24, 2004 | 06:37 PM
slickrick's Avatar
--Don
yeah it looks like a metra kit but i think he said he used the gxe dash kit.
Old Jan 24, 2004 | 11:44 PM
Tony Fernandes's Avatar
I'm not sure which kit he used, but I see along the bottom it color-matches with the lighter horizontal stripe. I thought only a GXE trim piece does this...I could be wrong. I just ordered the Sosche kit from sounddomain. It says it can be used for double DIN installation with some modification. We'll see. Whichever kit studman used, it looks good. Hopefully someone will ask him?
Tony
Old Jan 25, 2004 | 03:26 PM
DougJones's Avatar
Studman is using the GXE kit w/o the pocket.
I have the Scosche double-din kit, but I haven't installed it yet. It gives you the option of either single din w/pocket or double din. However, if you want the best fit/finish, I'd give Daveb a call and get the GXE kit.
Old Jan 26, 2004 | 11:45 AM
jjyznaga's Avatar
I ended up using the scosche kit. It is a pain to use. I had to drill the factory metal brackets so that the units would line up correctly with the trim piece. The Clarion VS735 dvd player I installed has a wider then normal face plate so I had to put the dremel tool to the scosche trim piece and grind it out so that is would fit properly. I also installed a Pioneer AVD-W6200 6.5" lcd screen to the headrest post of the passanger side seat. It came out good, just a lot of extra work.
RealityCheck
Oct 2, 2015 06:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
