Problem with a bass tube
Old Feb 4, 2004 | 04:42 PM
rrrfoma's Avatar
Here is the story.
I have installed an amplified bass tube today. But when I connected RCA cables (HU has sub outputs), it started to make "bum-bum-bum-...-bum" noise. Doesn't matter what music is playing ... doesn't matter how low-high volume is ... when RCAs disconnected evrything is fine (not a sound from it) ... even with one RCA plug (dosn't matter where and which one) it makes the same sound ..."bum-bum-...-bum"
Does anybody know what the problem is? ... - bad rca cable? - ... bad HU's sub outputs? ... - problem with bass tube itself?
Thanks,
Alex
Old Feb 4, 2004 | 04:57 PM
AscendantMax's Avatar
how are you running the RCA? is it near power cables/wires ?
Old Feb 4, 2004 | 05:07 PM
rrrfoma's Avatar
Nope ... power - left side ... RCAs - right one.
As I mentioned, even with one RCA plug connected it makes the same sound with the same amplitude ... a mistery for me ...
Old Feb 4, 2004 | 05:15 PM
how's the ground? make sure you scrape off some paint (if any) to make a good ground contact. all other connections are good?
Old Feb 4, 2004 | 05:18 PM
rrrfoma's Avatar
All of the connections are good - I'm sure about that.
I read somewhere that some amplifiers try to use RCAs as a "ground" but it shouldn't be the case here - when RCAs are disconnected - unit powers up. Any other ideas?
BTW, mounting was a challenge too. I ended up buying 2 self-tightening straps - easy to install the tube and easy to remove when needed (say to get access to a spare), and a very clean look too. Also can be used to tighten something esle in the trunk (when needed to prevent moving aroung the trunk).
Old Feb 4, 2004 | 05:25 PM
what kind of basstube?
Old Feb 4, 2004 | 05:29 PM
rrrfoma's Avatar
a cheap one - KOSS
I might mispresented the problem. I wasn't talking about an additional noise - this is the the only sound it makes ("bum-bum-bum")
Old Feb 4, 2004 | 05:36 PM
not sure man, kind of hard seeing the problem without being there. I'd try using a different set of RCAs in case the one you're using is bad. sorry I couldn't help much I know other people will chime in and give their $.02
Old Feb 4, 2004 | 05:39 PM
rrrfoma's Avatar
anyway ... thanks for your help
I'm going to try tomorrow connecting it to other "low" outputs (front/rear) and, of course, I'll try new cables (taking out everything again is not much fun ...).
Old Feb 5, 2004 | 12:24 AM
rrrfoma's Avatar
... anybody?
Mar 12, 2020 12:06 AM
Gingerheadman
Oct 1, 2015 05:11 PM
DBear
Sep 14, 2015 08:33 PM
popdedop
Sep 11, 2015 11:17 AM
