Am I Missing Anything?
Old Feb 11, 2004 | 09:42 PM
Hunter11's Avatar
I haven't hooked up a system in about 7 years so I need some help with the right wires. Do I need any thing else besides:
1) Power wire from amp to battery
2) Ground wire from amp to a ground
3) RCA cables from head unit to amp
4) Speaker wires
I just need to know if I am missing any wires. I have done this many times,just not in years and not in a Maxima.
I have a 12 I am gonna put in the trunk, but not right away. I got a new Kenwood HU and wanna go ahead and run the wires since I will have everything out already.Thanks!
Old Feb 11, 2004 | 11:33 PM
Nismo's Avatar
amp remote wire
Old Feb 12, 2004 | 05:37 AM
Hunter11's Avatar
Originally Posted by Nismo
amp remote wire
Oh yea, that is ran to the battery right?
Old Feb 12, 2004 | 05:53 AM
Supa Lao's Avatar
no, hook it up to the blue/white wire from the Kenwood deck
Old Feb 12, 2004 | 09:07 AM
C MAX's Avatar
4) Speaker wires
are you going aftermarket.. if so your gonna need an adapter which will make your application so much easier.. i got mine from crutchfield.. you plug into car harness and hook radio up to it .. then you can use the remote wire from the rear if you have the bose system.. i did about 7 max bose systems and thats how i do it..
Old Feb 12, 2004 | 08:45 PM
Hunter11's Avatar
Yes. Kenwood Excelon KDC-X879
Are you talking about an adapter as in the wiring harness for the car to the stereo? If so I already have that.
But what are you talking about when you say the remote wire from the rear?
The rear of the Kenwood? Or the Bose radio?
Old Feb 12, 2004 | 09:04 PM
djfrestyl's Avatar
Suspension Yoda
blue/white wire from the kenwood...goes right into the remote lead connection on the amp
Old Feb 13, 2004 | 03:21 AM
C MAX's Avatar
if you have the adapter, when you turn on your radio it will also power your bose amps in the rear.. you can tap into the power line in the rear. this will act as your remote turn on..
jmlee44
Oct 2, 2022 02:13 PM
conansriver
Nov 18, 2015 02:46 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
conansriver
Sep 16, 2015 12:17 PM
