BOSE vs. Standard system. Is there REALLY a big difference??
Old Feb 18, 2004 | 06:32 AM
MaxxAddict's Avatar
Hey guys. Are the BOSE sound systems all that they say they are? I mean, if I were to buy a maxima with a standard stereo system (the one on the GXE's) would it be tolerable for about a 1 yr until I either get enough money to replace it, or have enough money left over after I initially modd it out.
IS the BOSE really worth it? What do you guys think? Thanks!!
Old Feb 18, 2004 | 06:48 AM
infinitiblast's Avatar
Actually in the long run I think bose is worse.........speakers start sound farty.........and replacing the headunit with an aftermarket requires a specific adapter...........bose isnt worth it in my opinion.
Overall the cost to replace bose equipment is to high compared to replacing a stock gxe ssytem with aftermarket.
Bose just throws in to many variables.....
Old Feb 18, 2004 | 06:52 AM
MaxxAddict's Avatar
Yeah, that's kinda what I've heard. But the thing is, I probly won't have the money to get an aftermarket system for about another yr (roughly). Is the standard system CRAP? Or is it tolerable for that time period? Like.... what kind/size speakers does it have?
Old Feb 18, 2004 | 06:56 AM
mzmtg's Avatar
Minister of Silly Walks
If you plan on upgrading at all, skip the BOSE.
The standard system isnt total crap. It has 6.5" speakers all around.
Old Feb 18, 2004 | 07:38 AM
DoNcHoYaX1's Avatar
I wiuld recommend getting a HU. I did that, and I still could hear music with out any special adapter through the bose speakers and amps. I didnt connect one of the wires, because that made the sound go lower. its a orange one. I would do that, and then start by getting your components, and a amp. but you would have to re wire.
Old Feb 18, 2004 | 07:55 AM
I'd like to know what headunit you have........since bose speakers run at 1 ohm.
Old Feb 18, 2004 | 08:35 AM
DoNcHoYaX1's Avatar
its a sony old one, CDX C680
Old Feb 18, 2004 | 10:14 AM
dmplus's Avatar
I hate the cheap crummy look that aftermarked headunits provide. Some people dont mind a shiny aluminum bezel that sticks out like a sore thumb on the dash. For me the Bose system is good enough that i dont have to put in aftermarket. I would recommend listening to both systems (just take a cd to a nissan dealer and wander the used lot)
Old Feb 18, 2004 | 01:13 PM
minsbang's Avatar
i have a bose system.. I replaced the HU with a Pioneer DEH-P4400, and it sounds better.
Old Feb 18, 2004 | 05:46 PM
Ka$hThaRipper's Avatar
well what cars are u considering? don't let bose be the determining factor, cuz there's other stuff that is WAY more important than that..sure it looks good on paper (and if and when u try to resell ur car) but if u go with a GXE/SE without bose, than u can gradually add in ur system parts like donchoyax said
bose is great for stock system standards, but it's lousy in the longrun, just get non-bose
Old Feb 18, 2004 | 09:35 PM
ABS's Avatar
ABS
If you can tell the difference between a good system and a not so good system, then you will most definitely get frustrated with the sound quality of the Bose. At first listen it seems ok, but after some critical listening you will discover that the low end gets "farty" sounding, the high end lack and real attack and the mid-range is muddy. The Bose HU in my 2K2 was replaced 4x before I finally yanked it out. Also, the tone controls are VERY limited. Increasing the treble or the bass had only a very small impact on my system. Very annoying! Some people claim the Bose speakers are ok, but I've replaced mine and I can tell you flat out that they are only mediocre in terms of overall design/construction as well as sound quality.
My strong recommendation is to save the $1200 (or whatever they are charging for Bose now) and instead spend the money on aftermarket components. Your system will sound FAR better with aftermarket.
Old Feb 19, 2004 | 09:55 PM
joojoo2915's Avatar
Get a this or this + these + something like the 351s to power them and you will have a way better system than Bose for half the price.
Old Feb 20, 2004 | 02:14 AM
vqman
what specific adapter?
I bought an adapter off of sound domain...
I am installing my aftermarket Eclipse on Tuesday...
how can I tell if I got the right one? I don't want to go to the place to install my system and have them tell me it's the wrong adapter...
pics anyone?
oh yeah, to answer this guys question about the BOSE...
it does suck and is not really worth the money, but in my case, I HAD to get it...the Titanium Edition/Leather/Sunroof/HLSD/Heated steering wheel/etc...could not be had without also getting the BOSE audio system. If you don't want that stuff, go for a non-BOSE..but if you want that stuff, you'll have to get the BOSE.
-vq
Old Feb 20, 2004 | 03:22 AM
Maxima 504's Avatar
I have a new Alpine HU that i replaced my stock Bose HU with. Many people on here said that I need a $60 convertor, but this isn't true.. There is a way to hook up the HU to the stock Buse speakers(even if they are 1 ohn) so that you can hook it up.. The shop that did my install hooked it up without the harness and now everything sounds perfect, even better than before with the stock HU... The high are cleaner and much more loud..
Old Feb 20, 2004 | 06:31 AM
C MAX's Avatar
NO BASS!!!!!!!!! BUT OTHER THAN THAT A VERY CLEAR SYSTEM
Old Feb 20, 2004 | 07:03 AM
Ted_MEng's Avatar
Bose vs standard
In my case I have 3 Bose amps ruined by previous owner and I want to get stock HUcause I do like the stock double din look. The only aftermarket with similar green on black design (1 din though) is Nakamichi which is pretty expensive.
SO what is STANDARD GXE (2 din non BOSE I guess) HU anyway? Can I put external amp on and what's the sound quality (I guess it's made by Clarion)?
Old Feb 20, 2004 | 07:39 AM
C MAX's Avatar
do you have bose now. i have a spare bose hu and bose amp and speakers. i took them out my 97 still in good condition
Old Feb 20, 2004 | 10:26 AM
Ted_MEng's Avatar
The Problem is I don't wanna BOSE stuff except HU. I have aftermarket speakers.
Old Feb 20, 2004 | 10:56 AM
nghtfthlngknvs's Avatar
I'm not saying it's not possible, but i can't think of a way to make it work. sounds to me like you could be damaging your HU. if you'll check your HU specs, you will notice that the HU amp is only 4ohm stable so running 1ohm speakers can cause some serious damage. i'd find out exactly what the install place did and post it here since i would like to know(so i can temporarily use my 4"s in the front until i get my new JL components) and the people here will tell you if it's safe or not. if anyone has info on how to use the bose speakers with an aftermarket HU please post it.
Old Feb 20, 2004 | 10:39 PM
ABS's Avatar
ABS
It is possible to use an OEM Bose HU with aftermarket amps and speakers. There is a link in the FAQ that talks about this question. I think you will need a PAC adapter that costs about $60.
Old Feb 21, 2004 | 04:49 AM
Tony Fernandes's Avatar
If you have any inclination whatsoever to upgrade your system, do NOT get the Bose. Not only are you wasting your money on something you won't keep, but the Bose integration is horrible. It's gonna be much more difficult to upgrade the Bose system than the regular system. Just get the standard system and live with it for a while. Don't say we didn't warn you!!!
Tony
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
Pixel
Sep 15, 2015 05:53 AM
A32goldylocks
Sep 2, 2015 06:39 AM
