Ohms & Subs Wiring Question ? Help !!!
Old Mar 1, 2004 | 09:23 AM
rzayas144's Avatar
Can someone please explain ohms to me and how i should wire my subs.
I have two 12" RF Power DVC. They are dual coil and have two + and two - ports. i want to wire them so i get the best proformace and was hoping someone could help me. i and going to be running 4 channel 1600 watt amp just for the subs. and have another amp for everthing else. Can someone help want to have everything in by this weekend. Amp wire are run, radio is in the mail, custom box is being build ask we speak. Please Help !!! I am a n00b
Old Mar 1, 2004 | 01:59 PM
jmax
What is the nominal impedance for each voice coil? Can the four channel amp be bridged to two channels? What is the output power of the amp at various loads? WHat is the make and model of the amp?
http://www.rockfordfosgate.com/rftech/wiringwizard/
Old Mar 1, 2004 | 03:16 PM
rzayas144's Avatar
amp specs
the amp specs are on this page.
http://www.etronics.com/product.asp?...ore=&catid=305
and the subs are 2 12" RF Power DVC Dual 4 ohms Model # RFR2212
Old Mar 1, 2004 | 03:29 PM
nismos14's Avatar
§è~® f®ÈÄk
first dont waste your money on that amp. you can get a much better soundstream amp for like $50 less than that. as for wiring if you get a two channel amp, which is what i suggest, you just wire both the positives to one channel of the amp and both the negatives to the same channel of the amp from one of the subs and the same for the other sub.
i would suggest this amp http://www.millionbuy.com/souega2440.html its alot cheaper and better quality than that rockwood $55 less
Old Mar 1, 2004 | 03:50 PM
jmax
Are you sure about that model number for the subs? The closest thing I could find to that model number is the RFR3112. But you wrote dual 4 ohms so that doesn't match. You may have the RFD 2112. If you have a pair of dual 4 ohm subs I recommend sending that amp back and getting something worthy of the subs. With that amp you will only be able to give the subs 220 watts each, or 110 watts per voice coil. That's enough to get the subs to move but you won't realize most of the potential without a lot more power.
Old Mar 1, 2004 | 03:59 PM
nismos14's Avatar
§è~® f®ÈÄk
looks like ur stuck with that amp from ur other post. you're just going to have to wire each coil to one channel of the amp, 4 channels, 4 coils.
Old Mar 1, 2004 | 05:50 PM
rzayas144's Avatar
yea i am stuck
i am going to be doing everything on fri. i will see how it goes. i plan on getting another amp just not right now. i will just tell my pop that it blew up in a few months and that will give me some time to save for that amp.
Old Mar 1, 2004 | 05:53 PM
rzayas144's Avatar
yea that is the model # RFR2212, i just look.
Old Mar 1, 2004 | 05:55 PM
rzayas144's Avatar
http://www.lightav.com/car/rf/sub.html
there they are at the bottom
The Frye
Sep 2, 2021 11:03 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
