DEI 530t window module dipswitch settings. help...
I just installed my new viper 791xv alarm. Now I am installing the window modules 530t. There is a setting on the side of the module for the amount of force to roll the window up with. Just wondering if anyone else has installed these and what their settings are?
Thanks - The Chad
Thanks - The Chad
Thanks - The Chad
Thanks - The Chad
Thanks - The Chad
Thanks - The Chad
send a PM to PoLo...he has the same module and had to play with the settings before it worked correctly.
i installed 2 of these in my car. One for the front two and one for the back two windows. Turn all the switches up for the highest resistance.
as far as keeping the wires short, i have wires ran from the back two doors all the way around to my centersole with NO problems what so ever.
enjoy you one touch up/down windows!
Ant
Ant
I'm gonna go with ny96max on this one. I was planning on doing both window modules in the drivers door so I wouldn't have to run wires through all 4 door jams, just into the drivers. I also got another 10 guage wire from my battery just for the modules so they will have plenty of untapped power. Can't wait to install these....windows up and down from the remote...hehe.
Also got the 513t pain generator for my alarm and put it in my air vents. MAN that thing is loud!
Ant
Ant
I was referring only to the ground wire being short. It can be longer, but there have been problems in the past with proper grounding.
Indecisive, I do not recommend doing them in the doors, too much moisture.
--Don
--Don
--Don
), but now to get it to close.
Originally Posted by vsokolov
leave everything at factory settings
knight_yyz
Nov 1, 2015 01:34 PM
