How do you tell if your max had a bose or non bose original radio ?
Old Apr 2, 2004 | 09:43 PM
2001maximase5sp's Avatar
How would you tell if your max came with the bose system or the
non bose system ? I have a 2001 Se that has had the oem radio taken out.
The harness have been cut / spliced to hell and back . ( one
harness is about 2 inches long , the second is about an inch and a
half , and the third seems to be about an inch
if that helps any ? ? ? ? I seem to have what
look like tweeters on both front windshield pillars ? I meant to check the rear
speakers to see what they looked like .
Thanks,
Steve
Old Apr 3, 2004 | 04:42 PM
Playero's Avatar
Sanduguero
Thanks,
Steve
it will say BOSE in the HU
Old Apr 3, 2004 | 06:02 PM
scmaxima2k's Avatar
What about the rear deck. Only the bose equipped max's had the grill for the sub on the rear deck with BOSE on it.
-Steve
Old Apr 4, 2004 | 02:55 PM
[QUOTE]I have a 2001 Se that has had the oem radio taken out.
If I had a head unit , uh it would be uh simple to tell what it was ? ? ? ?
thats why I was asking , I only have the 4 door speakers ( and 2 on the wind
shield pillars ? ? ) no sub , no amp in the trunk , which I think the Bose had ?
So I guess it did not have a bose hu . Thanks .
Old Apr 9, 2004 | 03:51 PM
silvermax2k2's Avatar
it is very easy, look in your trunk. look at the back speakers. if you see a black unit attached to the rear speaks, you have bose. (the black unit is the amp for that speaker.) also, the rear speaker grill with say "bose" on it.
g/l
-Chris
Old Apr 9, 2004 | 03:57 PM
SEmy2K2go's Avatar
Go BUCKS!!!
g/l
-Chris
This would be true if in the 5th gens the rear speakers were mounted in the trunk.
Best thing would be is to pull out the radio and check the wire harness and check it vs. the wire diagram on studman's webpage.
Old Apr 9, 2004 | 10:02 PM
OneToughMax's Avatar
you guys aren't paying attention...
he can't pull out the oem deck and look at the harness, because it's already been pulled out and the harness has been cut off
check this out steve: pop your trunk, then look at the bottom of the parcel shelf. on the passenger side, there may be a black box. this is (was) your bose amp, if so equipped. it is also very possible that you have a bose subwoofer in the rear as well. this will be visible on the bottom of the parcel shefl smack in the center. If you do not have a sub or amp back there, congratulations! you do (did) not have a crappy bose system!
Old Apr 11, 2004 | 11:23 AM
Playero's Avatar
Sanduguero
[QUOTE=2001maximase5sp]
lol sorry i think i rush reading your post....lol
Old Apr 11, 2004 | 09:43 PM
thanks for all the feedback , the system was not a bose , the radio / cd unit was an older mid 90's model clarion . Got the new Kenwood cd / mp3 / sirius system going over the weekend , pretty easy hookup , sounds great even on oem speakers , they are next , also got the satellite turner and antenna , but listed them on ebay , with the mp3 deck , i don't need the saellite now . touched one wire the wrong way and lost dash , parking lites , and blinkers !! luck was on my side 4 a change , just a fuse . Thanks again ,
Steve
Old Apr 11, 2004 | 11:19 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Glad that you were able to get everything working properly. Hopefully we didn't overload you with our views of what you should have done to find out.
9aj9
Apr 5, 2020 12:11 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
