Who's wired in one of RedMax's screens? You? look inside...
Old Apr 8, 2004 | 11:18 AM
FLO_BOY's Avatar
hey --
what did you attach the REMOTE TURN ON wire to in your car?
did you do what RedMax did and wire BOTH the power wire and the REMOTE
wire to a switch??? I'd like to not do that...Has anyone wired in a relay???
What type of relay did you use?
THANKS!!!
FLO_BOY
Old Apr 8, 2004 | 02:16 PM
1MAX2NV's Avatar
I don't have one....but why not wire it to the headunit's remote turn on?
Old Apr 8, 2004 | 02:39 PM
Igor911's Avatar
Thats what I said to myself when I read his post
Old Apr 8, 2004 | 03:09 PM
FLO_BOY's Avatar
well, I was thinking of wiring it to the AMP REMOTE TURN ON, but,
should the power wire go straight to the battery??? or ???
need some help...
THANKS!!!
FLO_BOY
Old Apr 8, 2004 | 04:17 PM
Chitwista's Avatar
need some help...
THANKS!!!
FLO_BOY
If you go straight to the battery (without a switch) the unit will always have power.. But if you go to the remote turn on lead of the h/u, the monitor will only power up with the h/u, and turn off when you turn off your radio..
Old Apr 8, 2004 | 08:52 PM
1MAX2NV's Avatar
Power to ACC +12V.
Remote turn on to Headunit's remote turn on.
Old Apr 8, 2004 | 09:16 PM
FLO_BOY's Avatar
Power to ACC +12V.
thanks.
so, I'm gonna hook up the power wire to the ACC12V wire,
and then hook up the screen's "+ive turn on" to the HU's "external amp control lead" (that turns on the amp when the unit powers up).
To be honest, I am making an assumption...as I don't have a "remote turn on" labelled in the HU's wiring diagram...
I hope I'm not freaking any one out, I'm actually pretty handy...I'm just getting a li'l nervous as this is gonna be a big install...
FLO_BOY
Old Apr 8, 2004 | 09:41 PM
Redmax's Avatar
Redlinemax Owner
Do not connect it to the amps turn on if you have more than one amp hooked up. because you don't want too many things connected to that lead. connect the screen to constant power at the radio and then put a switch on it
Old Apr 8, 2004 | 09:47 PM
TEEdotMAX's Avatar
OFF TOPIC... will redmax's screen fit into a 00 max??? lots of customizing needed??
Old Apr 9, 2004 | 08:23 AM
FLO_BOY's Avatar
only one amp...and the screen. I'd like to avoid having a switch.
BUT, if this is not OK, I'd appreciate advice saying as much...
thanks,
FLO_BOY
Old Apr 9, 2004 | 10:15 AM
1MAX2NV's Avatar
Typical headunit remote turn will have enough current to "turn on" 3 amps. You could always wire a SPDT relay then you will have 30AMP worth of turning power. That way you could turn on 100 amps if you want.
thanks,
FLO_BOY
Old Apr 9, 2004 | 02:13 PM
TravisC's Avatar
Yeah, lots of customizing, I'm working on it right now. There is also another thread for screens in a 5th gen. I've just gotta paint mine and I'll be posting pictures so watch for it.
Old Apr 16, 2004 | 11:43 PM
BORQUA79's Avatar
nycmaximas member
So that Orange wire turns on the unit and the red keeps the constant juice on? So when the HU is on then the screen is on? Because Id rather not have the screen on unless I have a Movie on... I figure the screen being on all the time isnt cool for the screen. Im confused any help please? Oh and having both the red and orange together like Red said is together on a toggle switch?
Old Apr 17, 2004 | 06:41 AM
erty67's Avatar
Decal Specialist
I just left the remote lead disconnected and I turn it on and off using the remote.
Old Apr 17, 2004 | 07:21 AM
BORQUA79's Avatar
nycmaximas member
Thanks Erty67 I think I'll just use the remote control for now... but If I use the Cigarette Lighter Power could It still be functional as a Lighter?
Old Apr 17, 2004 | 07:31 AM
erty67's Avatar
Decal Specialist
I don't see why not. To be honest, I have mine wired to the radios power wire. I spliced the constant into the radios constant, and the screen's remote turn on to the radio's ignition, but I disconnected it later on to use the remote for turning it on and off.
Old Apr 17, 2004 | 07:38 AM
BORQUA79's Avatar
nycmaximas member
Ok that sounds good... So I have that option Im just nervous to start splicing stuff all over the place what did you use for a ground? But I like the "just using the remote control" Idea...
Now I just have to find a way to cut out an opening in my armrest compartment to put the DVD palyer... I guess Im using a dremel or sumthing?
Old Apr 17, 2004 | 07:42 AM
erty67's Avatar
Decal Specialist
i grounded to a bolt somewhere under the dash. I don't remember where though.
Old Apr 17, 2004 | 07:44 AM
BORQUA79's Avatar
nycmaximas member
Great now Im set... Lets see what happens... Thanks
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
