single sub setup
Old Apr 9, 2004 | 10:29 PM
jtm087's Avatar
single sub setup
For those of you with only one sub, how do ou keep your sub from sliding around your trunk?
Old Apr 9, 2004 | 10:32 PM
OneToughMax's Avatar
put L brackets on your sub box and secure them to the trunk floor or seat back
Old Apr 9, 2004 | 10:48 PM
Kojiro_FtT's Avatar
It tends to sit in the sagging part of the trunk over the spare tire well, lol. But I will be making a false floor and using l-brackets to secure it.
Old Apr 9, 2004 | 11:57 PM
slickrick's Avatar
hey kojiro, can u make a write up of some orts on hwo to exactly do this. i keep my sub box right over the spare tire because it osunds the best there, but it constantly slides around. using velcro just moves the box with the carpet, and screwing lbrackets into carpet does nothing also.
Old Apr 10, 2004 | 05:38 AM
RideTheMax's Avatar
take out cardboard flooring, add 1/4-1/2 plywood floor. drill L brackets (4-front,back,left, and right)into the flooring, place box b/t brackets. this way you don't have screw into box and you get rid of the sagging in trunk. or you could follow above directions and screw it into the box, then the floor. I figure save your box and just set the box in the middle of all brackets.
Old Apr 10, 2004 | 08:15 AM
I am going to do this also. My "plan of attack" is to remove the trunk carpet, lay it on a sheet of 1/2" plywood or mdf (probably plywood), trace the outline of the carpet, cut with a jigsaw, then glue the carpet to the plywood so it doesn't slide everywhere. is there a better way to do it?
James92SE
142
Jan 2, 2024 09:23 AM
DJLAX152
May 4, 2021 11:46 AM
Apr 16, 2020 05:15 AM
spazma7ik
Jan 12, 2017 09:38 PM
Max139617
Sep 29, 2015 06:44 PM
