Radio wire color codes "need quick Response"
I need a quick answer to this question.. Im installing subs into a 1997 Nissan Maxima using the Factory Cd Player "non-bose", and I have the line out converter but Im not sure what wire colors to tap into does anyone have the wire color codes or has done this before?...thanks for the quick responses
Constant 12V+ Pink/Blue
Switched 12V+ Blue/Black
Ground Vehicle Chassis
Illumination Red/Blue
Dimmer Red/Orange
Antenna Trigger Black/Red
Antenna Right Rear
Front Speakers 6 1/2" Doors
Left Front (+) Blue/White
Left Front (-) Blue/Yellow
Right Front (+) Brown
Right Front (-) Brown/White
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Dimmer Red/Orange
Antenna Right Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Originally Posted by Andyman692
okay, you have a line out converter?? is that like an rca cable or something? All you need to do is splice an rca cable into 1 channel and then run that to your amp
Please do not do this. You will be very unhappy with the results. As well as shopping for new equiptment.
--Don
--Don
--Don
To clarify, you hook the speaker wire to the converter then plug the RCA male ends into the amp. The converter takes a crappy HU with no RCA outs and gives it to em, though I would recommend getting a decent HU instead.
Maxima_Joe
Nov 25, 2015 08:19 AM
sake1bs
Sep 19, 2015 09:32 PM
doobadoo
Aug 15, 2015 06:43 PM
