low volts
Old May 16, 2004 | 07:32 PM
raymond3414's Avatar
low volts
My voltage meter has been getting low readings lately and it is making my JL 1000.1 amp cut out because of the volts being so low. I was wondering if my battery was bad or could it be my alt. or do I need to do the magic 3. I also have a PPI amp powering my comp. speakers but they never cut out due to the low volt why is this?
Old May 16, 2004 | 08:23 PM
slickrick's Avatar
id try the magic 3. how low is it going? must be going pretty low for the jl cut out.
Old May 16, 2004 | 09:08 PM
AscendantMax's Avatar
how many volts is it reading with the engine running? it could be your alternator headin south
Old May 16, 2004 | 09:14 PM
nghtfthlngknvs's Avatar
most likely the alternator... but first thing i would check is the amp ground.
Old May 17, 2004 | 07:22 AM
Maxima Dan's Avatar
I agree. When the alt goes you normally have some other issues as well. I would definately check out your amp ground, might be corroding.
Old May 17, 2004 | 06:44 PM
The volts drop below 10.5 when the car is running and the system is on. I have to turn the bass down or turn down the volume to make the amp come back on. I guess I'll do the magic 3 and check the ground.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
