Need help in choosing Amp...
Hey guys, I'm seriously considering jumping on the deal that thezeb has on those CDT CL6a component set and a pair of CL6 midbass for the rear. Would my headunit handle these until I can afford to amplify them? I have a Pioneer 7400MP which has 50Wx4.
What would be a good amp to power these babies? I was thinking of just getting a pioneer amp or maybe a jbl. Also, how would I hook this up? Would my HU need more than one preout? And, would a 4channel amp with say 50Wx4 be sufficient? Is the signal coming to the amp already amplified from the HU?
Thanks for any help. As you can tell, I'm new to this. All I have right now is a Kenwood 1000W amp and 2 10s and Alpines in the doors and rear deck. I'm just wanting better SQ.
Thanks,
drew
Thanks,
drew
if youy want those speakers to sound like they should AMP THEM!!
stay away from pioneer amps
you have 3 x RCA Pre-Outs ( Front, Rear + Sub)
so adding another amp is not a problem..
if you tell us your budget we can help you find an amp accordingly
you can run the cdts off that h/u fine until you get an amp. you might even like them enough without an amp. but id get a 2 channel amp and run the front off it and run the back off the h/u.
Thanks for the advice!
drew
Originally Posted by bluemaxdriver4
I can probably spend around $200 for an amp. What is a good brand amp to go with? I heard JBLs are decent... this true?
drew
drew
also try rockford fosgate, jl (lower series amps)
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Would this Rockford 300s amp be enough to power the front speakers?
Also, when I hook the amp up to the front output RCA from my HU, will it already be amplified any by the HU?
Thanks a lot!
drew
Thanks a lot!
drew
Originally Posted by nismos14
will what be amplified by the hu? the speakers? yes you have to run speaker wires from the amp to the front speakers
Sorry for the confusion, but as you can see I am definitely a newbie at all of this!
Thanks,d
drew
No it wont, the output gives VOLTAGE not power. The voltage is basically the signal strength of the music signals going to the amp. A higher voltage level results in cleaner signals with less chance of noise.
carid
Sep 9, 2015 05:06 AM
umnitza
Sep 1, 2015 01:03 PM
any other q'z?
