Running a wire for amplifier
Old May 18, 2004 | 12:42 PM
suprropmp's Avatar
How did you guys run the amp wire through your cars? Did you drill a hole and just poke it through or is there already a hole I can use?
Old May 18, 2004 | 02:19 PM
AscendantMax's Avatar
i just drilled a hole for my setup
Old May 18, 2004 | 03:05 PM
kgb006's Avatar
drilled a hole next to the brake pedal
Old May 18, 2004 | 05:04 PM
suprropmp's Avatar
did you guys seal the hole in any way? sorry if the question sounds stupid but I've never installed an amp before
also, how did you lift your carpeting up to run the wires?
Old May 18, 2004 | 05:12 PM
SuperChris's Avatar
Infiniti 35 Double G's
drilled hole thru the firewall just left of the power steering pump(?)...came out above and to the left of the brake pedal; and yes, you should use a rubber grommet(sp) to keep your wire from being shredded by the sharp edges of the hole.
as for the carpet, just pull it up...i was scared of doing that too, but it looks the same now as it did before the install; BTW, the door sills along the floor just pop right out...easy to do, won't hurt anything.
good luck....
Old May 18, 2004 | 06:29 PM
yeah i ran mine along the door sills too. not sure if it's the same on other gens, but on my 3rd gen, the sills are held in by 4 plastic screws. after the plastic screws are removed, remove the 4 tabs. then the thing just comes off.
Old May 18, 2004 | 07:14 PM
suprropmp's Avatar
uhm, i dont see any platic screws... I tried taking part of it off (on the drivers side) but it didnt budge and I dont really want to break something in there
Old May 18, 2004 | 08:14 PM
like i said, i'm not sure if it's the same on your gen max. i'm sure others will chime in and help ya out
Old May 19, 2004 | 03:59 PM
OneToughMax's Avatar
on a 4th gen the door sills just pop off. in the driver's kick there is a plastic nut that holds the kick panel to the floor - you can just unscrew it by hand. the sills are just held to the metal with little clippies
Old May 20, 2004 | 09:53 AM
wickedmax's Avatar
i wired my car this past weekend, SOOO easy. DO NOT DRILL in your firewall. i have a 97 so it should be the same. just find the black rubber cap in the firewall. pluck it out and thread the wire through so it comes out near the pedals. then lift up door sills. PM me w/ any other ?'s
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
