help with wall
Old May 21, 2004 | 05:48 AM
sk24iam's Avatar
help with wall
I'm making a wall to put up against the metal behind me rear seats. What is the best way to attach it?
Old May 23, 2004 | 08:05 AM
sk24iam's Avatar
anyone got any ideas?
Old May 24, 2004 | 03:29 PM
nismos14's Avatar
§è~® f®ÈÄk
yea, take away the back seat, remove 2 - 4 of the 10 mm bolts that are there, get longer bolts or screws, and screw them into the same holes with the wood piece mounted in there, and let it secure it there, i used two peices of small plywood to mak eit sit straight instead of angled straight against the back of the seat.
Old May 25, 2004 | 11:20 AM
damadmonk's Avatar
i used 3/4" mdf... about 18" x 36" large. There's actually a bunch of various holes in the metal behind the seat that you can use. Figure out which holes you want to use, have a friend sit in the trunk holding the board in the spot where you want it, and mark your holes.. then use washers, long bolts, and nuts to secure it in... I used 4, one in each corner. Obviously you lose the passthru... but i don't know that many people who use it.
tnewbs
Aug 28, 2015 10:15 AM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
