6.5's won't fit
Old May 24, 2004 | 08:46 PM
phillysmoswantd's Avatar
6.5's won't fit
i just bought some pioneer 6.5s to put in my front speakers but they wont align in with the original screw holes. am i supposed to glue them on or drill new holes? thanks
Old May 24, 2004 | 09:06 PM
eckohb's Avatar
the right speaker size is supposed to be 6 3/4...correct me if im wrong, but according to crutchfield, thats what it is.
Old May 24, 2004 | 09:07 PM
bOdhi's Avatar
Correct you are, if you want 6.5's you'll have to have a special install. Otherwise you're limited to only 6 3/4 or 6.75 (sometimes referred to on eBay). Sorry =[
Old May 24, 2004 | 09:10 PM
this whole time i was led to believe that they were 6.5s. i think i can try to glue them on...
Old May 24, 2004 | 09:30 PM
Zigg's Avatar
There are adapter brackets that can be purchased. Gluing speakers just scares me.
Old May 24, 2004 | 09:34 PM
aznprid972's Avatar
i manage to fit 6.5 pioneers in the front. it was a tight fit but i got all 4 screws in and it's still holding up. try just finger tighten in the screws first then tighten alittle at a time and take turns on all the screws.
Old May 24, 2004 | 09:56 PM
bOdhi's Avatar
Can you return them for 6 3/4's? Surely the warranty can't be up? Your safest bet would be to do that, but if your at a last resort, I'd say they'll be okay >.<
Old May 24, 2004 | 11:53 PM
oTranscendental's Avatar
If you can return them and get the right size., if not make sure that you seal all the air space around the edges, and the original speaker housing/ if you dont, your speakers bass will suck, and you will get fluttering distortion noise.
I had this happen to me when some crappy audio store replaced my speaks in my 3rd gen. If you live in Maryland, DO NOT GO to Auto Radio Center. They are halfazzed biotches.
Old May 25, 2004 | 02:19 AM
WillMax95's Avatar
its 6.5"
you might need the speaker brackets, did they come with them? they are a little ring that has a bunch of holes around the sides.
Old May 25, 2004 | 04:56 AM
Conrad283's Avatar
I need a truck
I have 6.5's in the front. They fit ok
Old May 25, 2004 | 07:21 AM
95BLKMAX's Avatar
SOME 6 1/2" speakers come with the oversized ring already installed in them, that's why some of you are saying that you have 6.5" in the front and no problem. But some speakers come with their regular 6.5" ring and those are the ones that would need an aditional ring to fit the 6 3/4" opening. That's why in Crutchfiled you see that some speakers say they are 6 1/2", while others say 6 /12"-6 3/4".
Old May 25, 2004 | 10:51 AM
keanders21's Avatar
I have some 6.5 CDT's with a one inch spacer and they fit fine in the front.
Old May 26, 2004 | 10:40 AM
thanks guys, i managed to fit my 6.5s in the holes. i screwed the screws in from different angles so that it would fit.
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
Sep 27, 2015 08:37 AM
Pied
Sep 26, 2015 03:29 PM
