What to seal sub box with?
Old May 31, 2004 | 02:17 PM
suprropmp's Avatar
For those of you who made your own (sealed) sub boxes what did you seal them with?
Old May 31, 2004 | 03:41 PM
sk24iam's Avatar
Liquid nails and silicon caulking/.
Old Jun 1, 2004 | 07:53 AM
Supa Lao's Avatar
I just use liquid nails
Old Jun 1, 2004 | 08:41 AM
suprropmp's Avatar
so would this do it:
http://www.liquidnails.com/caulks/ac-138.html
Old Jun 1, 2004 | 10:23 AM
Supa Lao's Avatar
i use this:
http://www.liquidnails.com/adhesives/ln-901.html
Old Jun 1, 2004 | 10:28 AM
Supa Lao's Avatar
i use this:
Old Jun 1, 2004 | 10:45 AM
thekenone's Avatar
yeah ilquid nail is the way to go. i have a suggestion for you that i hadn't heard of till i fininshed my second box. the back pannel (opposite of the speakers) use weather striping. glue it to the back piece and screw it together. not fully cause if you pinc it too much air will seep thru. but this way you can acess the back of the speaks cause its not permanetly sealed but is still air tight
Old Jun 1, 2004 | 11:41 AM
OpTi's Avatar
what's the difference between liquid nail and silicone?
Old Jun 1, 2004 | 11:51 AM
slickrick's Avatar
dunno but caulking or even wood glue works fine.
Old Jun 1, 2004 | 12:22 PM
Maxima Dan's Avatar
Gorilla glue. http://www.gorillaglue.com/ This stuff is ideal for enclosures. It expands to fill all gaps making the box air tight. Just be careful to wear gloves when working with it, it dyes you hands a nasty yellow/brown and needs to wear off.
Old Jun 1, 2004 | 12:25 PM
Kojiro_FtT's Avatar
Wood glue is used for the joints when you are assembling it, but the liquid nails/silicone should be used for the corners when it's done to make sure it is air tight, as well as around the terminal cup.
Old Jun 1, 2004 | 12:37 PM
Shinnjee's Avatar
Dappy from home depot.
James92SE
142
Jan 2, 2024 09:23 AM
mpbclutch33
Dec 26, 2015 11:11 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Sep 27, 2015 08:37 AM
