where is the HOle in the firewall 4th gen
Old Jun 2, 2004 | 02:55 PM
onecrazymaxnut's Avatar
and can it fit a 2 gauge wire?
Old Jun 3, 2004 | 05:03 AM
Guinader's Avatar
hey I was looking for the same thing (trying to install my sub).
onecrazymaxnut did you find a good place?
Old Jun 3, 2004 | 06:21 AM
Pearl96Max's Avatar
I tend to get a bit irritable
If auto then drill where the clutch plate goes. If manual drill to the left bottom of the gas pedal. Both easily accesible and will fit a few 0Awg wires.
--Don
Old Jun 3, 2004 | 05:30 PM
Guinader's Avatar
this tread should be a stickie
Old Jun 3, 2004 | 07:14 PM
i still havent found it..but im sure there mustt be a gromet that alows wires to go in some where from the engin bay...ill look for it this wknd...
Old Jun 3, 2004 | 07:58 PM
Pearl96Max's Avatar
There really isnt one, but Ive only done about 90+ Maximas. Although some people take the long route and go through the fender somewhere. Rule of thumb, keep the distance of the wire shortest possible.
--Don
Old Jun 4, 2004 | 12:29 AM
suprropmp's Avatar
so don, where do you suggest to drill the hole?
also once its drilled what kind of grommet should i use or rather how should i seal the hole up?
Old Jun 5, 2004 | 06:01 AM
thekenone's Avatar
Originally Posted by mzmtg
Remove the wheel well liner of the left-front wheel. You will see a very large grommet with a large wiring harness running into the passenger compartment. This is the pferfect place to run a wire into the car and along the left side of the car.
in the faqs
Old Jun 9, 2004 | 05:25 AM
Guinader's Avatar
ok, I removed the tire and the plastic cover, and I found two holes, one mentioned on the tread above, and a smaller one where the hood cable goes, it is a bout 2 inches wide, perfect for any cable.
on the inside of the car I had a hard time.
I removed a ABS circuity box and all the insulation covers, then I ran my 4-gauge cable as deep as it could go on the carpeting, under the plastic cover of the seat belt, and under rear seat. (professional JOB)
It is very simple, just take your time.
thanks for all the help.
MAXSE5SPD
Sep 17, 2022 04:00 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
