door locks for keyless alarm
Old Jun 13, 2004 | 12:25 PM
NookieMax's Avatar
alright, so i went out and got a cheap keyless entry alarm from ebay, you get what you pay for. anyways,
the instructions show me the alarm puts out a positive and negitive "door triggers", but out cars have simple lock and unlock wires, both of which run positive. does anyone have experience with this, or have any ideas on what i should hook up to the door locks.
its an "options group" alarm, if that helps.
thanks
Old Jun 13, 2004 | 07:19 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Door "triggers" are irrelevant to door locks. The trigger is what tells the alarm the door was opened. The door Locks are for the keyless entry. In which case they are Negative in Maximas, NOT positive as you thought. They are also located IN the driver door. If you need the wire colors let me know.
--Don
Old Jun 30, 2004 | 12:58 AM
isac's Avatar
the wires are gonna be in the drivers door, it's a light green with red stripe to lock, and a green with yellow stripe for unlock, they are both at the switch, and they are negative triggered, meanig that when you send a ground pulse it will lock or unlock depending on which cable you are tapping. You are also probably gonna need to wire those up with some relays.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
