Help with rattling trunk.
Old Jun 15, 2004 | 05:32 PM
CaLSoNiC
I've got an annoying rattle in my trunk, actually its my spoiler. I know this, because if I push on the spoiler, the rattling decreases a ton. The spoiler is actually starting to come off the trunk lid. Whats the best way to resecure it? I was just thinking of using some super glue or something, but there has to be a better way.
Old Jun 16, 2004 | 07:48 AM
WHOS UR DADDY's Avatar
you can either go to the dealer and spend $3 each on spoiler clips or you can but some silicone at HoeDepot and put in on the surface.
Old Jun 19, 2004 | 11:24 PM
Devchuck2g4's Avatar
same prob here...would dynamat help if i installed it on the trunk lid itself? and spoiler clips?! what do these look like because mine are held down by 8 screws
D
Old Jun 21, 2004 | 04:59 PM
imxelite's Avatar
Goto home depot and buy some expanding foam that stops expanding once it reaches the max of what it's in. I did this to my spoiler and no more rattles out of it. It actually put more weight on the spoiler as if you were holding it down with your hand.
Old Jun 21, 2004 | 06:43 PM
AscendantMax's Avatar
can't the spoiler be tighened down?
Old Jun 21, 2004 | 07:40 PM
DaKeG's Avatar
i have two "10's and they hit very hard. My trunk also rattles. I have noticed that there are worn paint spots. I'm going to put some dynomat down on those spots. Check your trunks paint.
Old Jun 23, 2004 | 04:31 PM
sk24iam's Avatar
Yep same problem here. I was only able to tighten the spoiler to a certian point and it still rattled. I'm thinking about buying some edead v.3 to paint the trunk with. The rattling can only be heard from outside so it's not relly a problem.
Old Jul 9, 2004 | 10:19 AM
Wil's95SE's Avatar
我爱台湾
hey guys take it from someone who experienced this for a while. I would check the l.e.d. inside the spoiler cause that was my problem. My 10's hit so hard they made the l.e.d. come lose in the spoiler. Since there was no way I could take it apart and fix I opted to be without the l.e.d. part on my spoiler for awhile and it made a world of difference. I also have about 2 or 3 coats of Dynamat extreme right where my spoiler is mounted on my trunk. I dynamatted the entire trunk just for safe measure. Also check your spacers on your spoiler cause they could be worn and need replacement.
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
