Whats the Best place for Ground in 4th Gen Trunk
Old Jun 20, 2004 | 06:03 AM
SiMpLyMaXedOuT's Avatar
is there a place anywhere in the 4th gen trunk that people would recommend as the best ground? i was thinking about the rear strut bolt?
Old Jun 20, 2004 | 07:41 AM
craig10114's Avatar
dont ground to that, either ground to one of the bolts where your jack is, or use the bolts that hold that metal bracket in thats behind the rear seat
Old Jun 20, 2004 | 05:26 PM
nismos14's Avatar
§è~® f®ÈÄk
i used the rear strut tower bolt works fine.
Old Jun 20, 2004 | 05:48 PM
ShRapNeR's Avatar
ditto..............
Old Jun 21, 2004 | 06:11 AM
GodFather's Avatar
Made in Taiwan
i just drilled a hole in the ceiling by the speaker, and bolted a screw and a nut. It matched the way i want my amps to locate. it's nice, dude...
Old Jun 21, 2004 | 04:14 PM
sk24iam's Avatar
I have rear struts but I'm going to have to cahnge that because of sometimes having engine noise.
Old Jun 21, 2004 | 04:38 PM
SuperChris's Avatar
Infiniti 35 Double G's
i used one of the screws/bolts that secures one of the taillights...perfect fit.
Old Jun 22, 2004 | 07:24 PM
gto400no1's Avatar
grounded it into the scew that holds my box in place. sanded away the painted surface, and havent had any problems yet, had the system for almost a year now.
Old Jun 23, 2004 | 10:32 AM
Batxel's Avatar
blah
Got 2 amps hooked up to the rear strut bolt. No noise whatsoever (80 amps max draw power). Don't forget to sand the surface.
Old Jul 2, 2004 | 06:14 AM
Bmr4life's Avatar
rear strut bolt will rust and corrode. at least it did on my car.
My new ground point is underneath the rear seats where the seat belts bolt into the chassis. Sand/strip paint off and you should be set.
Old Jul 2, 2004 | 07:34 AM
gtr_rider's Avatar
192.168.1.1
I have my ground in the same location, works fine
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
