rear deck sub
Old Jul 24, 2004 | 09:01 AM
Burnett's Avatar
rear deck sub
want to replace rear deck sub with after market, but i want a 10 inch sub woofer instead of the 8. my problem is i need a different type of bracket to mount because the bracket the factory (BOSE) are mounted on are crap.
Old Jul 24, 2004 | 01:36 PM
Rider69's Avatar
not sure how the 2002s are, but in my 99 to use the rear deck for a sub I would have to replace the trunk lift rods that run across the underneath rear deck
Old Jul 24, 2004 | 01:41 PM
Robert_J's Avatar
Sounds like you need to make a custom bracket among other things. A trim ring out of MDF is pretty simple. Just make sure the sub you get will work as a free-air sub. Look for a high Qts (or a high Qms). Also, the stated power handling of a sub is for the voice coil only. For example, an Adire Tempest (15") will handle 600 watts electrically. If you mount it in an infinite baffle configuration, it only takes about 140 watts to bottom it out. Bottom it out too much and you destroy it.
-Robert
Old Jul 24, 2004 | 01:46 PM
Rider69's Avatar
Not too mention that you would also probably want to reinforce the entire rear deck so that it does not rattle like an SOB or fall apart for that matter.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
