System Setup
Old Jul 28, 2004 | 02:34 PM
Max Mutes's Avatar
System Setup
I've recently installed a DVD/MP3 Headunit and a 7" Flush TV screen. For the Headunit I used a $25 Bose Adaptor kit. What I've noticed since then is that the sound is nowhere near as loud as it was when I had the Bose in. Also, I didn't hear/get it at first, but now I have Alternator whine coming in through the speakers. My friend gave me a supressor though. Now, if I was to wire that do you guys think it would really work OR if I changed all of the stock System altogether (which I AM going to do...well, trying) would the sound automatically dissapear? On the other side of things, as I just previously said I'm tryin to finish the whole audio/video system setup soon. I been planning on getting (4) 6-3/4 Polk db Series Speakers (using stock Front A-Pillar Tweeters and installing rear B-Pillar Polk Component Tweeters, a Kicker 8" 0r 10" Solobaric L5 mounted in the trunk whole, facing into the car and a Lanzar Viberant Vibe428 Amp. Does anybody know where I can find good speaker wire and amp wire to run all of this? I hear Skosche is good, but I dont know about anything else and where can I get good deals on the stuff. Also, if you know anywhere I can get any of those for cheap other than ikesound, crutchfield, cardiscountstereos.com, etc. then please let me know. Thanks guys.
PS: Also, do you think that one Sub will make a lot of rattlin and what is the perfect fit? I measured corner to corner 12" but side to side and top to bottom at 9 inches...So would a square 8" fit better or 10"...?
Old Jul 31, 2004 | 01:25 PM
Max Mutes's Avatar
Damn, thats whats up. Thanks for all the replies.
Old Jul 31, 2004 | 07:02 PM
kcidmil's Avatar
I think the reason why there was so little, is that you have so many questions and bounce around alot to different subjects. I can answer the suppressor question, that was already in covered in a thread
http://forums.maxima.org/showthread.php?t=327166
For the subs. SEmy2K2go has 3 8"s in his car. http://www.cardomain.com/id/semy2k2go
I'm not sure for your gen, but you might be able to adjust your latch mechanism on your trunk, pulling it down more. Keeping it from rattling.
I know it's a pain trying to look through all the threads for the info you want. But next time try not to ask so much in one paragraph. Break it up into a 2 or 3 paragraphs, asking exactly what you want to know. Makes it easier for everyone.
Good luck with your system
Old Jul 31, 2004 | 09:00 PM
nismos14's Avatar
§è~® f®ÈÄk
is the adapter adjustable? what kind of head unit is it? try the suppressor depending on where ur sound is coming from u may or may not still have it with the rest of the components replaced go to walmart for good wiring kits go for a 4 gauge kit and get a spool of wire too. thats all the help i can offer for now
also dont buy the stuff off those places, get it from an authorized dealer if u dont u may end up getting burned....
Old Aug 1, 2004 | 05:10 PM
Max Mutes's Avatar
Well, the adaptor isn't the so-called SoundGate Adaptor that everyone seems to be talking about, if that's what you're referring to. It's simply a wiring harness to connect the Bose wiring harness to the Aftermarket one, so I didn't have to individually cut and splice each wire.
When I had the Bose Double Din Headunit in, I loved the sound and loudness of the speakers, but since switching Headunits, the speakers aren't as loud. I'd rather not get a system, but I don't know what to do to regain the loudness back. Do I have to bypass the amps in each speaker or as previously stated, buy that SoundGate Adaptor?
My sound I suppose is coming from my speakers because when I turn off the Headunit, the noise goes away completely. Also, thanks for your suggestions man.
Old Aug 1, 2004 | 08:27 PM
nismos14's Avatar
§è~® f®ÈÄk
how are the bose speakers getting their signal? if it is from the pre-outs of the headunit u may want to re do that and run rcas from the head unit to the line level inputs on the harness.
Old Aug 2, 2004 | 05:47 PM
Max Mutes's Avatar
Ay man, I'm kinda confused is there anyway I can meet up with you one day and you can just take a quick look at it and tell me what you think? I asked my friend, but he doesn't really know about the whole Maxima/I30 Bose System setups. If you can that would be great. BTW, I'm like 20 min from Rutgers
Old Aug 2, 2004 | 09:21 PM
nismos14's Avatar
§è~® f®ÈÄk
sure i'll let u know when i have a day off from work
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
