Installing Amp Wire
Old Aug 2, 2004 | 05:58 AM
SKYRockerr's Avatar
Installing Amp Wire
I am having trouble running a wire from the battery to inside the car, i have a 2002 nissan maxima se , without bose system , i am going to install a amp with a aftermarket HU , i need to run the red power wire from the battery to the trunk , i found the opening i tried to go via coat hanger and i was unsucessfull in getting the wire thru, there is a patch there with cotton and metal behind it inside the car, do i need to drill a hole in it? is there a easy way to run that wire without drilling holes?
please assist, i am sure there is a faq for it, but i was not able to search for it.
Old Aug 2, 2004 | 11:12 AM
MIXXMAX's Avatar
Yes, drill a hole in it and make sure there isn't anything on the other side where the drill bit may hit. File the edges of the hole and put a rubber grommet inside the hole so that the wire doesn't pinch from the metal. Run the wire on the same side of the battery and under the door sills thru the trunk. It may be easier to remove the bottom half of the back seat to fish the wires to the trunk.
Old Aug 2, 2004 | 01:16 PM
SKYRockerr's Avatar
Now is there a way to run the wire without drilling holes? anyone run the wire thru the side fender?
any pictures?
thanks.. trying to avoid holes..
Old Aug 3, 2004 | 06:32 AM
SKYRockerr's Avatar
Pictures of your amp wire installations here people!
Old Aug 5, 2004 | 02:50 PM
SKYRockerr's Avatar
bump......
Old Aug 5, 2004 | 08:05 PM
suprropmp's Avatar
I'm not sure about 5th gens but my 4th gen had a perfect hole. If you look at the engine bay it should be right in the middle on the firewall. It was covered with a little black rubber piece that just popped right out. I'll try to get a pic of it tomorrow.
Old Aug 6, 2004 | 05:22 AM
SKYRockerr's Avatar
I know what you are talking about, i have a little perfect hole with rubber in it, its by the power steering pump, i am going to see if i can pop off the rubber tommrow thanks
Old Aug 6, 2004 | 03:31 PM
suprropmp's Avatar
yep, thats the one i used
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
Abdelrhman
Aug 17, 2015 12:16 PM
