Need help hardwiring a Valentine 1
Valentine 1
does anyone know how to hardwire the V1 into my 99 max SE-L??
the link in the how-to's is dead, so, i dont know what to do. i just need to know which wire to splice, im so lost...
Originally Posted by endus
Just use the positive wire that runs to the back of the cigarette lighter.
lemme know if you have questions..
You guys really need a writeup? Come on guys. Find a switched positive wire. Clip the wire tap on to it. Attach the ground wire to a screw or some other piece of metal. Seriously, it's not hard...you don't even cut and splice any wires....it literally could not be made any easier. The only piece of info that would still help is what color/tracer the positive cig lighter wire is....once we find that out just slip the tap on that one.
If you're not going to use the cig lighter wire then you need a multimeter to help you find a switched positive wire. That is going to complicate things immensely if these guys need a writeup on how to clip a tap on to a wire. Stick with the cig lighter wire....it is the easiest and safest possible solution.
As far as the cig lighter, the wiring inside the car is all exactly the same size. There is absolutely nothing about the wiring to the cigarette lighter that is any different than any other wire in the car. The only possible difference is the size of the fuse on the cig lighter circuit, but since the cig lighter is designed to handle small accessories (i.e. a radar detector) the size of the use should be fine. If it wasn't then the answer is just stick another fuse in there.
Actually mine isn't wired to the back of the cig lighter since the wire that came with the V1 wouldn't quite reach the way I ran it and I didn't feel like finding it at the fuse box. I just used a multimeter and tapped another switched +12v source. You can wire it to the cig lighter closer to the drivers side of the car though...you just need to find the wire.
Another way to do it would be to buy a fuse tap and then just connect the wire to the fuse tap. To be honest, though...no insult intended, if you need a writeup for clipping a tap onto a wire finding a +12V fuse socket with a multimeter might be too much. It IS a nice clean way to install it though...that's how my changer is wired.
Pfft, i did it myself with out any 'write ups'.
Here's how I did it.
1. find where you want your unit to go to.
2. get the cable you need, short or long.
3. Take out center pannel (I have stick) and get access to cig lighter, so you can see the cables.
4. Find out which one is the possitive.
5. After finding out which one is possitive and negative, use the clipper which came with your V1 unit and clip on the POSSITIVE wire!. After you made sure it holds well, connect the wire in there.
6. For the negative one, you have to find one of the bolts which Grounds, I found that type of bolt under my gas pedal.
7. Connect your negative wire to that ground place, and make sure everything holds well, and will not come off if you accidently touch it.
8. Find where you want to stick your connection unit into which the wire from V1 unit will come in(the one which has 2 wires sticking out and which you connected to + and -) (I put it under my stearing wheel)
9. Here's a pic. of where my unit is
I know i suck at writing 'write ups', but at least that should get you started...and thats how i did it
ive seen it all, been doing car audio for 6 years, ecu's, bcm's, everything that is electrical can be blown by a wrong move, so watch yourself..
my 0.02, believe me or dont, its all good
I know....that is why I want to know the REAL way it is supposed to be done to the fuse box without messing with the ignition wires....I wasn't gonna do that just to hook-up a radar detector...that is crazy..
$400 on the website www.valentineone.com you find find them slightly cheaper on eBay (the new 1.8 used goes for about 350 - 375). IMO you're better off buying it from the website.
Originally Posted by mclarke
Are you serious? do you know that wiretaps will eventually rust and break the wire? i guess you try to do things the wrong way... not a good idea..
Mine has been wired this way for 2+ years with no problem. I know others who have had it installed this way for far longer, no problem.
Let's also not gloss over the fact that you are advocating splicing into the ignition wire. Are there conseuquences if your ridiculous rusting scenario happens? Absolutely. I am telling them to splice into the cig ligher wire. If you're ridiculous rusting scenario happens there, who cares? Now do you understand why the cig lighter wire is the best choice? The only risk in this ficticious rusting/wire breaking scenario is a short, and that's why you tape over the tap.
Agreed there... but the wire color is the same on all maxima's, hell all nissans for that matter, even infinitys, etc... ignition wire colors do not change with nissans, or hondas, or toyotas, etc...
ok now i know you have NO IDEA what you are talking about.... every wire is the same in the car huh? so those 40 or 50 amp fuses under the hood that are for the IGNITION lines are 12 gauge? yupp might wanna try looking or reading again buddy...
Your statement was that the cig lighter wire was not able to handle the current: that statement is patently false. It is the same size wire as every other wire that is in the area we are talking about, where any reasonable person would hard wire their detector. Add to that the fact that almost all detectors come with a plug to plug into the cig lighter....do you honestly think that every radar detector manufacturer in the world is taking some insane risk by providing cig lighter plugs?
so any switched wire huh? airbags are switched wires, might wanna rethink your strategy...
fuse taps, yupp thats always safe... idk people its your choice, a smart way and a not so smart way....
Please also explain how people with 0 electrical knowledge are supposed to wire their detector without a wire tap and without a fuse tap.
Originally Posted by ExoticCreations
Does any one know the cheapest place for a Valentine 1? I know u get what u pay for but some guy told me $500. Thats a little to high, Is it?
Your best bet is to use the wire tap that Valentine includes and tap into the positive cigarette lighter wire. If mclarke was right about rust being a major problem (which he is not) then the worst possible problem that could happen is that you're cigarette lighter stops working.
Clip the tap onto the wire, then use electrical tape to tape over the tap. That way, even if it *did* rust for some reason, there is no risk of a short since all the wires are taped together and the broken power wire would ahve nowhere to go to short out on something.
also... scotchlocks rust out every day bud, have you seen some old stuff in cars? im telling you from working in the industry for a long time? if you have maybe its because your in a different area? but up here it does...
I'm also still curious how these dudes who obviously don't solder are supposed to splice the wire without it.
EDIT: Also, and I'm not saying this to be a jerk specifically to you, but working in the industry does not really say anything about how much you know what you're doing. Stereo install shops are running amp power wires on top of gas tanks and generally doing insanely stupid/dangerous things every day.
I just did mine for my 2001. Its not that hard. Total time for me was about 1 hour. That was from taking breaks and stuff from the heat. Its fairly simple, just that I need to have a site to host my write up. I'll get to it for people when I get home from San Francisco.
A-
A-
Y2KevSE
72
Aug 4, 2008 08:21 PM
i would luv you....
