WTF amp died out already by just moving it !
Old Aug 22, 2004 | 11:04 AM
2 Da Max's Avatar
ok my amp was on and i lifted it at an angle and then there was a short pop with a yellow light and then smoke came out, well it smelled like something burnt. I checked all of my fuses and the fuse on the battery was gone. Someone told me i shouldnt run the amp of the cig lighter fuse because of too much voltage on the amp? the amps not even mine. if i fix the main fuse would it work? plz i need help
Old Aug 22, 2004 | 11:05 AM
2 Da Max's Avatar
i mean the remote wire from the cig lighter fuse
Old Aug 22, 2004 | 11:21 AM
nostrixoxide's Avatar
Dude, you never ever ever ever want to hook your remote wire up to a constant 12v source. The remote wire needs to be hooked up to a switched circuit. Like the ignition switch! Otherwise your amp will be on 100% of the time.
I don't know what to tell you about the amp, because I physically cannot check it out. But it's not good when you smell electrical stuff burning. More then likely just replacing the fuse isn't gonna do the trick. Your amp is probably toast? If you stick your nose right up to the amp & take a good wiff, does it smell like fried electrical. if it does then it's for sure needed repairs if it can even be repaired. Best way to know for sure is to take it into your local car stereo shop (not circuit city or best buy) but a decent audio shop. And have them test it for you. they will be able to tell you right away if it's ok or not. Sorry to hear about the mishap.
Old Aug 22, 2004 | 11:35 AM
2 Da Max's Avatar
thanks for the advise man. a lot of my friends are telling me the same thing with the remote wire, but the dude who put it in for me is biching and saying o its ok ive been workin with amps for all my life, but i will listen to you and i will run it to the ignition switch.
Old Aug 22, 2004 | 12:01 PM
Cool, so you know for sure then that the amp isn't broken?
Old Aug 22, 2004 | 09:13 PM
2 Da Max's Avatar
i dont know for sure man, because this morning i checked and found out my main fuse from the battery was shot, so im going to get a new tommorow and let you know, thanx for asking though
Old Aug 22, 2004 | 09:27 PM
Alright man, I await your reply....
Old Aug 23, 2004 | 12:30 AM
salgue's Avatar
its ok to hook up the amp remote lead to this cars cigarette lighter since it is in fact switched with ignition.
Old Aug 23, 2004 | 12:53 AM
Nismo's Avatar
the cig lighter is not a constant source, it turns on when the key is in acc
Old Aug 23, 2004 | 08:26 AM
2 Da Max's Avatar
im confused. alot of ppl told me to not run it to the cig lighter, should i leave or rewire it? i duno ill guess ill put it to the ignition. but if its not a constant source wat if your chargin your fone or sumitng?
Old Aug 23, 2004 | 09:47 AM
nyautostyle's Avatar
basically when the cars on the amp is on even if your stereo isnt on. this is not really good because its been over used for nothing. just run it to the ignition and let it at that. when u tell me u smell burning, u most definitly burnt your amp. but good luck with it
Old Aug 23, 2004 | 10:04 AM
SKYRockerr's Avatar
You need to install a aftermarket headunit with a remote out.
Or buy a switch / circuit install in the car so you cut if off or on when the car is on.
Old Aug 23, 2004 | 10:57 AM
2 Da Max's Avatar
YOOOOOOO i jus replaced my main fuse on the battery and when the amp turned on it caught on fire !!! WTF
Old Aug 23, 2004 | 08:36 PM
Dementia's Avatar
If its toast, not under warranty anymore and you're really ****ed off... take it out to a shooting range and shoot the crap out of it with a large caliber rifle. It'll make you feel better... trust me After having mine repaired 3 times... I hated it with a passion.
Old Aug 24, 2004 | 06:40 PM
nismos14's Avatar
§è~® f®ÈÄk
what kind of amp is it anyways?
Old Aug 24, 2004 | 08:20 PM
2 Da Max's Avatar
lol power acoustics 820 its a rice amp its see through with a neon light
Old Aug 25, 2004 | 05:08 AM
nismos14's Avatar
§è~® f®ÈÄk
that probably has alot to do with why it caught fire, of course there could be wiring issues from the install as well but if nothing else checks out i'd say it's the amp itself.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
