UD pulley and stereo
Old Aug 26, 2004 | 04:26 PM
MyownNismo's Avatar
Future Camaro SS owner
I have a 1000 watt amp running two 10's. I also have one 1 farad cap and stinger deep cycle battery. Will a UD pulley be bad for my situation.
Old Aug 26, 2004 | 04:41 PM
2 Da Max's Avatar
if your talking about an underdrive pulley, and the altenator, then i guess the altenernator will do its job still, well probably even better since the udp would spin much faster than a stock one, so your battery would be charged up quicker.
Old Aug 26, 2004 | 06:00 PM
waveridr85's Avatar
absolutly wrong the pulley spins the same speen but has a shorter circumference thus moving the belt less causeing the alternator blet to not move as fast.
I cant answer your question but you could probably get away with a blue top and a cap
Old Aug 26, 2004 | 08:28 PM
2 Da Max's Avatar
lol my bad i wasnt thinkin bout dat
Old Aug 27, 2004 | 06:51 AM
MyownNismo's Avatar
Well Unorthodox racing makes a SC pulley. Which is basically a lighter pulley than stock which gives you thr HP. It isn't a underdrive cause it isn't smaller. I will get that one.
Old Aug 27, 2004 | 07:53 AM
Magikone69's Avatar
i have my udp and a 2000 watt amp pushin 3 audiobahn 12's. no problems for me..... but then again i only had my udp for about 4 months. pics on my website
Old Aug 27, 2004 | 12:26 PM
04RedOpMax's Avatar
Maxima of the Month Winner
An underdrive pulley does turn the alternator slower than the stock pulley (at a given RPM), but this has no effect on how it charges the system, because an alternator charges throughout the entire RPM range, even at idle.
In the "old" days, cars had generators which put out lower voltage at slower RPM's. This is why they don't put generators on cars anymore.
I have an Unorthodox Racing UDP on my 04' Max, and have had no problems so far. As a bolt-on performance item, I recommend it. Good bang for the buck.
Old Aug 30, 2004 | 07:50 PM
image's Avatar
im running a yellow top.. to 0 guage.. to a cap.. to a ditro... then to my (2) JBL 1200.1 Amps and a JL Audio 300.4.. you think i will be able to do a UDP set? I doubt it.. but worth a shot.
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
