Need Help choosing Battery Terminal
Old Aug 30, 2004 | 02:11 PM
y2KAOSMax's Avatar
I have a 2000 Max and I'm getting a Optima Battery. I can't use my current Positive terminal b/c it won't reach. My current terminal has a fuse on it. Not sure how many amps the fuse is b/c I haven't checked yet. What would be a good Battery Terminal to use that has a fuse holder or could I buy a fuse and connect it to the wire?
Old Aug 30, 2004 | 07:53 PM
image's Avatar
stinger.....
Old Aug 31, 2004 | 01:53 PM
y2KAOSMax's Avatar
I know Stinger makes a good terminal but do I have to get one that has a fuse to match my factory one or can I add a like fuse to the line that has the fuse attached to it?
Old Aug 31, 2004 | 02:11 PM
image's Avatar
You seem like your talking about a fuse holder.. dont be confused terminals connect to the battery or a amp... or a ground, kinda same concept... You can buy a fuse holder, splice your power wire next to the battery... put wire in the fuse holder.. and do the same on the spliced end and then connect a ring terminal to it and hook it to your batteryy..
Old Aug 31, 2004 | 02:36 PM
Conrad283's Avatar
I need a truck
Stinger expert terminals with LED voltage meter
Old Aug 31, 2004 | 02:59 PM
Maxima Dan's Avatar
knukonceptz...save your money for something that will improve your system.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
