1999 Maxima SE Amp/Headunit Install help
Old Aug 31, 2004 | 06:19 PM
DcMaN's Avatar
i just need to know a few things. Which dash kit is needed for the headunit install if needed at all. Where should i ground the amp to once everything else is done. and where should i run the power through, i think theirs a rubber grommit by the power steering pump if im not mistaking i just want to confirm this. And if theirs anything else i should need to know feel free to tell me asap thanks. My friend said that he grounded the amp to one of the bolts underneath the seats. Would some one be so kind and tell me how to remove the seats step by step thanks.
Old Aug 31, 2004 | 07:54 PM
YellowOne's Avatar
if i remember right there's a grommet to the left (standing in front of the car) of the master cylinder on the firewall. i ran the power wire through that under the carpet to the trunk. as for how to remove the back seat all you have to remove is the piece you seat on there's 2 tabs that you pull forword on about calve high when your seating on the rear seat one on each side. just pull them forward and lift up
Old Sep 1, 2004 | 03:06 AM
DcMaN's Avatar
what about the headunit the kid didnt tell me if he has the bose stereo so im not sure if he does or not if anyone could tell me what is needed for the bose system and without the bose system that would be great.
Old Sep 1, 2004 | 12:10 PM
DcMaN's Avatar
The audio system is NOT bose. and it has no extra pockets. Its double din. any help on what dash kit i should get
Old Sep 1, 2004 | 04:54 PM
YellowOne's Avatar
just go to best buy they should have a pocket, if not try a junk yard. as for a wiring harness wal-mart has them for around 9 bucks.
Old Sep 2, 2004 | 03:51 AM
OneToughMax's Avatar
yeah just stop at best buy for the pocket. it's made by metra. as for going through the firewall, if it's an auto, you can punch a hole through the firewall where the clutch assembly would normally bolt up.
Old Sep 2, 2004 | 10:30 AM
DcMaN's Avatar
i thought there was a rubber grommet i could just slide the wire through ?
Old Sep 4, 2004 | 10:33 AM
SuperChris's Avatar
Infiniti 35 Double G's
i got a 99SE...i never did find the extra hole next to the power steering pump everybody talks about, so i ended up drilling a new hole for the power wire...no big thing, won't hurt.
Old Sep 4, 2004 | 11:03 PM
i dunno. i think if you make your own hole and put a grommet in it looks alot cleaner and more professional. then people who look at your car know that the hole was made for power wire to run through. if you poke through an existing grommet it makes you look lazy
Stagnet04
Sep 2, 2015 07:53 AM
Dman1989
19
Aug 17, 2015 03:44 AM
Team STILLEN
Aug 10, 2015 04:29 PM
MikesChevelle
Aug 6, 2015 11:36 AM
