will this be a problem
Old Sep 13, 2004 | 05:28 PM
generation3's Avatar
I have a die hard battery that has some corrosion on the positive terminal and a little on the negative. (theres some white stuff that forms around the terminal) If I hook up my wiring to this battery will the metal be eaten through?
Old Sep 13, 2004 | 05:48 PM
DMad8724's Avatar
sand it off with some tin foil or something
Old Sep 13, 2004 | 07:59 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Mix baking soda with warm water and pour it on liberally. Depending on how bad it is, use a wire brush, youll be fine.
DMad...Ive never seen AnyThing "sanded" with tin foil....
--Don
Old Sep 13, 2004 | 09:11 PM
slickrick's Avatar
--Don
is that the old "coke" trick my dad used to do on my old car? yeah dmad what are you thinking?
Old Sep 13, 2004 | 09:22 PM
guyincognito's Avatar
same thing happened to me, just disconnect the battery and wipe it down with a baking soda solution, works extremely well
Old Sep 14, 2004 | 12:23 PM
DMad8724's Avatar
yeah whatever rub it with tin foil, f u guys lol
Old Sep 15, 2004 | 08:35 AM
Wil's95SE's Avatar
我爱台湾
use a wire brush to get it off. just be careful and try not to get it in the eyes.
Old Sep 15, 2004 | 12:45 PM
AscendantMax's Avatar
i used the baking soda method...worked great.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
