what ohm load is this?
I know that if you have two 4 ohm SVC subs hooked up in parallel on one channel the amp sees a two ohm load. What about running two 4 ohm subs in parallel bridged mono on the amp? Is it still a two ohm load?
What about running one dual voice coil sub, with both voice coils hooked up to a bridged amp? Would the amp see a two ohm load there too?
I am trying to get the most out of my amp with the least amount of speaker in the trunk and need some help. I have an old punch 200x2 currently powering a P1 15" punch in bridged mode. Is this a four ohm load? RF claims that this amp produces 400 wrms bridged at four ohms. It doesn't sound like that much power to me but maybe I am used to it since I have had this amp since like '98. The sub is in a cheap, pre-fab, sealed box too, which may be part of the problem too.
Sorry to ramble, but when I was young, I would just hook up two subs in stereo and call it good cause I didn't know about all this Dual voice coil, ohm load, parallel wiring ect. jazz. Thanks
-Robert
Thanks so much for the help. BTW, the sub is a new P1 and it is a four ohm speaker. And I know it is hard to put a finger on what 400 watts "sounds" like but I am just basing it off of what I "remember" it sounding like before. Like the butt dyno, this is a bad way to measure, I know.
So from what you said running one dual voice coil speaker in parallel is the same as running two single voice coil subs in parallel right? And the amp would work as if it is a one ohm load in each case, correct? The reason that I ask is because I had problems with the amp shutting down because of heat or stress when I had two SVC subs running in parallel off of it on bridged mode. Now that I have just the one single voice coil sub running running in mono, I haven't had any problems. I was considering getting a dual voice coil sub to replace it but I don't want to run into that problem again. Now, I think that I will build a ported box for the one I have and call it good.
BTW how do the boxes with the slotted ports sound? I have only heard the ones with tube ports.
-Robert
Yeah, I think that I will build one to spec from my manual for the sub. It calls for a 4x9 inch tube port in a box that is 2.5 cubic feet, I think. I just have to find some place that sells a port though. Also, I hear you have to have a special blade on your saws to cut 3/4 mdf so it should be interesting. But I will feel better building it myself I think. Thanks for the help.
It calls for a 4x9 inch tube port in a box that is 2.5 cubic feet.
-Robert
jmlee44
Oct 2, 2022 02:13 PM
Mar 12, 2020 12:06 AM
fastcarny
Oct 6, 2015 10:42 AM
bryants95max
Oct 2, 2015 12:52 PM
