car audio in a home
Old Sep 28, 2004 | 04:23 PM
craig10114's Avatar
car audio in a home
so i was at a party at my school over the weekend and the kid had 2 towers that he built with cerwin vega car subs loaded in each one with pioneer car speakers all around using a regular home receiver. is there any way to add a car amp to this setup to really get the power out of a sub like that?
Old Sep 28, 2004 | 04:40 PM
erty67's Avatar
Decal Specialist
You may want to warn your friend that he could damage that receiver by hooking it up that way. maybe/maybe not....depends on the impedance value of those speakers. most home audio equipment is set up for 8ohms. If he is running 4ohm speakers, running it at higher volumes and/or long periods of time may cause the amp circuit to overheat. Personally, I would not suggest car audio in a house. As for runnign a car amp in a house, it can be done. I really don't think it is worth it though.
Old Sep 28, 2004 | 05:21 PM
craig10114's Avatar
he is using DVC subs wired to 8 ohm
Old Sep 28, 2004 | 05:34 PM
erty67's Avatar
Decal Specialist
then he should be ok. as for the car amp, you would need a power supply that could handle the load of a amplifier. A car battery charger with a huge cap(to clean up the DC voltage) may work.
Old Sep 28, 2004 | 06:16 PM
2 Da Max's Avatar
so how do u get a house amp to work in a car?
Old Sep 28, 2004 | 07:16 PM
sachmo12345
me and a friend hooked up his homestereo subwoofer with a built in amp to his car but it only worked for like 3 seconds.. its not worth it
Old Sep 28, 2004 | 07:27 PM
AscendantMax's Avatar
you got it the other way around . he was wondering if he could use car stereo for home use.
Old Sep 28, 2004 | 09:35 PM
erty67's Avatar
Decal Specialist
power inverter and keep everything 8 ohms
Old Sep 28, 2004 | 11:38 PM
DJ Kontakt's Avatar
car amps draw too much power. a $200 power inverter will really only allow you an amplifier that puts out 350w.
I run 4 ohm car speakers in my home too. My reciever does 4 ohm easily, and my subwoofers have separate amps that also can easily run at 4 ohms.
Its expensive to power the subs, but you can get a decent 4/8 ohm reciever for only $40 off of ebay.
Old Sep 29, 2004 | 03:26 AM
2 Da Max's Avatar
i have an old skool 250 watt sony amp with a manual eq on it, its pushing my 10inch rockford in a tube, nd ive always been using car speakers in my house
Old Sep 29, 2004 | 03:28 AM
2 Da Max's Avatar
but it did blow one of my optiumus speakers though
Old Sep 29, 2004 | 06:35 AM
craig10114's Avatar
yea im getting ready to redo my home system and i wanna do it right this time, i just bought an onkyo receiver (100x7) and im gonna hook that up to Bose speakers but i need a lot of bass so i was thinking about building a box for a cerwin vega 15 that i have laying around but i just need to figure out how to power it
Old Sep 29, 2004 | 07:59 AM
DJ Kontakt's Avatar
get the 300w plate amp from www.partsexpress.com
CV subs are pretty loud with little power, that amp should do the trick.
Old Sep 29, 2004 | 09:28 PM
machinehead's Avatar
severe waste of time. You can get better home stuff for cheaper than car stuff.
Old Sep 29, 2004 | 10:53 PM
DJ Kontakt's Avatar
$55 for the best pair of components I have ever owned, in my room.
$60 for the reciever
$89 for my sub
$89 for the amp for the sub
I will put my speakers up against anybodys home system of comparable price.
To each his own, but IMO mine sound better. Maybe its just because I know what Im doing.
Use ebay to buy stuff, save a ton of money.
Old Oct 3, 2004 | 08:35 PM
Saddles's Avatar
I use a HAM radio 10 amp power supply to run a 300watt amp to a 12 in my house. Works fine. Cost me like $40 on eBay
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Aug 16, 2015 07:25 PM
Slamrod
Aug 10, 2015 12:33 PM
MikesChevelle
Aug 9, 2015 11:50 AM
mrgooch
Aug 9, 2015 11:00 AM
