More Problems
Old Oct 3, 2004 | 07:06 PM
sachmo12345
More Problems
it seems that everything is wired up fine checked everything over like 6x but the amp MTX 801d still reads as if there is a problem with a red LED
Old Oct 3, 2004 | 07:09 PM
2 Da Max's Avatar
pwr, ground.? can the amp get an overload from the headunit? it happened to me when i installed my head unit with the remote wire. the amp was gettin too much power when i connected the remote wire, it just turned red. then again i dont know much bout electronics
Old Oct 3, 2004 | 07:14 PM
sachmo12345
so what did u do to fix it
Old Oct 3, 2004 | 07:15 PM
2 Da Max's Avatar
ok it could be, ground wire is not secured, the voltage goin into the remote is too low, the system employs too many amplifiers you may need a relay, the speaker outputs are shorted,
Old Oct 3, 2004 | 07:17 PM
sachmo12345
why would amp come on if the ground was bad
Old Oct 3, 2004 | 07:18 PM
2 Da Max's Avatar
tell you the truth my boy put in my head unit, u know what u should do, take the remote wire and tie it on the audio fuse under the steering wheel and see what happens
Old Oct 3, 2004 | 07:19 PM
2 Da Max's Avatar
the amp would stil come on with no ground at all it happened to me and thats how i blew my first amp bad ground, well lol no ground but do the thing with the remote wire
sachmo12345
if the remote wire was bad than th amp LED shouldnt come on at all i would think
Old Oct 3, 2004 | 07:33 PM
2 Da Max's Avatar
no if the remote was bad the amp is still getting power from the batt
Old Oct 3, 2004 | 07:34 PM
2 Da Max's Avatar
i dont want to give u no wrong info man jus wait till someone who knows more than me post, im just tellin u wat i know, sorry if i couldnt be helpful enuff
Old Oct 3, 2004 | 07:35 PM
sachmo12345
its all good
Old Oct 4, 2004 | 03:28 AM
2 Da Max's Avatar
so u got it workin?
Old Oct 4, 2004 | 06:09 AM
sachmo12345
no hopefully today I will work on it
Old Oct 4, 2004 | 10:14 AM
yogi's Avatar
What exactly is happening.....ur amp is just going into protective mode?(red light coming on) if that's the case then redo ur ground.....the fastest way of checking if u have a good ground is :
1. disconnect the REM wire from HU
2. on the amp connect the REM wire to 12V
3. leave the ground as it is now
IF the amp still goes into protective mode check the power wire for any cuts etc. if u can, do an continuity test on the wire itself.
one more thing........on almost all never amps the amp will not turn on if ur RCA are busted.....check into that too
if u could say what excactly is happing to amp(did ur amp work before etc etc) that woudl be really helpfull
godo luck
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
